My one truck started its life with a brief stint in Onterrible and came to me equipped with one of those rust preventer modules.  The same truck also had been back to the dealer multiple times with electrical problems surrounding the crank position sensor and they never resolved it under warranty.  First thing I did was unhook and toss that module in the garbage after the truck went into limp mode and threw a code for the crank position sensor shortly after I bought it.  I knew something was up when I cleared the issue by just disconnecting the battery.  No module and it's been fine for almost a year now lol.
I just pull the taillights and the rocker plugs, flush, allow to dry and fluid film.  Much better preventative method.
That's possible everyone has a different  story. Have no issues with mine and the dealer does my undercoating since new and let me say this there's not one spot of rust and its 3 years old. The underneath is well protected with whatever so called GM approved stuff it is I'm not sure. Nova Scotia has some of the worst salt roads that will ruin a vehicle in a hurry if not mantained.
I recently finished repairing some of the rust in the rear end (under the bed) on my 2016 Sierra 1500 AllTerrain (came from NJ, has 40k miles now). Sincerely, it is disappointing that these trucks rust so badly so quickly. 30-year old cars have undercarriages in better shape. Regardless, I think the wax GM is using is indeed a good product, the only problem being thin application. When cleaning it off to prepare for painting, the spots where there were tears (i.e., thick application) it was very resistant to getting off of the frame, and the metal underneath was intact. On the other hand, spots where the layer was very thin is where it washed off quickly, and water and contaminants started penetrating from there on - hence the peeling.
I had no issues with rust since the dealer undercoated my 17 High Country from new, they used whatever so called appoved GM product. Well all I can say they didn't miss anything and dealing with salt for almost 3 years in Nova Scotia was a good test. They also installed a rust module some say it's useless but I'll keep doing what's needed to keep it rust free.
I've decided to kiss this frame goodbye in about 5 years and build a galvanized one to support V8 tuning (if the motor and cab stay well by then). Anyway, not sure how the previous owner treated the undercarriage given salty NJ roads, but just looking at condition of very old vehicles that have not been specially treated is disappointing (and appears to be by no means exclusive to GM trucks).
Weather and salt make the most difference; the frame coating is really not robust to all conditions across the US.
Dealer done mine the undercoating before it left lot, seems to holding up 3 years and rust free and I live in Nova Scotia a true test.
Well, don't feel too bad, guys! Friend has a 2020 Silverado and GM evidently didn't make any changes to their frame wax. The truck is less than two months old and it already has surface rust at the welds. Different looking frame though, instead of round tubes cutting across the frame in the rear, they use square tubing. Didn't crawl under it and see if anything else is different, but the rust and wax looks the same.
I fluid filmed my 18 a month after I bought it...I reapply twice a year. 48,000 miles and almost two years later, it looks pretty darn good. But I don't think I should have had to gone through those extremes to keep my frame clean.
It's been a real bad winter here in New England, not a lot of snow, but a ton of ice and salt. Everyday it's been a thorough salt bath.
My 17 High Country is rust free and 3 years old, lots of undercoating applied yearly by the dealer as part of the sale. We live in Nova Scotia where any vehicle is bathed in salt
Yeah, you guys are using Krown up there, right? Fluid Film or Woolwax seems to be popular where I am. Think Woolwax actually owns Fluid Film, go figure.
Known or Fluid Film is a popular choice yes. As for what's under mine only the dealer knows lol
Is this happening to the 2018 models as well?  I haven't seen that year mentioned.
I used POR-15 in the past on my 66 GTO frame and under the body when it was off.
I think you meant Krown?
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
