2019 Chevrolet Silverado Photographed During Cold Weather Testing
If GM offered 4:30 gears in their 1500, they would probably do worse than Toyota. There was a towing test done with 5,000 pounds between a Chev 1500 and a Tundra, all the gimmicks only got 2 mpg better loaded , with less Power - 5.3 vs 5.7.
Those 2 MPG are HUGE when it comes to the CAFE standards though with the number of trucks that GM and Ford sells.
  • Replies 77
Percentage wise, a 2 MPG on a truck is a much bigger bang for the buck improvement than a 5 MPG increase on a small car that already has fuel sipping economy.
I believe over half the trucks sold to individuals never do any truck work. Lets get real many are just used as daily drivers to and from work . Sure they used the bed ....went to wal mart and put new bar-b-cue grill in bed and brought home etc. Hell lot of them vever tow anything or ever leave pavement. Commercial buyers its a whole different ball game.
Has anyone ever looked underneath a Yota? The "bigger axle" isn't exactly beefy or cutting edge. Their transmission has different ratios, hence the difference in rear gearing. Even with AFM, I think I'd still rather have a 5.3 than that archiac 5.7.
Sent from my SM-G920V using Tapatalk
The only thing I see that I don't like on these trucks spied, is the dam door mounted mirrors. Why not just stick with the style mounted flush to the door like the current truck? No...we go for a car style mounting a la Camaro, Corvette, Saturn Vue/Captiva...I have a feeling the tow mirrors will look strange as hell.
I hope these spy pics are seriously deceiving, or they are going to ruin it, 100% grocery getter.
..HD trucks have become grocery getters...the consumer market is the drive behind all the changes from all the truck OEMs. Sure, they engineer a strong truck, but not all the gadgetry is driven by those that actually USE their trucks. Look at the radios they have now in these things. Some changes are purposeful...EPS, AUTO 4x4, HID and LED lighting, but a lot if this stuff is driven by SUV and car consumers that want trucks. Platinum, High Country, Laramie Limited, Denali...look at the trim levels that have risen out of the change.
Also, some of the hardware changes are EPA/CAFE driven like EPS, AFM, high efficiency axle lubricants, 8, 10 speed transmissions, GDI, $20 a quart low viscosity full synthetic transmission fluids (the 8L90 and the 10R90 use some $$$$ fluids).
So are the auto companies supposed to go against what their customers want? They are in the business of selling trucks to the most people possible, not building a stripped down rock crawler or tow rig that only enthusiasts on forums will talk about buying.
Better fluids = longer life. Look at the ZF-8 in the FIAT line up. Fluid is $43/L for the transmission, filter is integrated in to pan. Kiss away close to $1,000 for a fluid & filter change.
The new POTUS had said he would freeze or possibly scale back the EPA/CAFE regs as they are getting out of control.
The manufacturers cannot keep up, getting ridiculous.
I will not own an AFM/EPS vehicle unless my hand is forced, both are troublesome. At least the HD series from Ford and GM are devoid of this garbage, as is the Tundra's.
I absolutely hate how GM forces you to get every option under the sun to get the 6.2. I don't want any of that crap.
Look at atv's, EPS systems have been around for nearly a decade, looking at over $1,200 to replace a box once it goes. They are far from reliable, and for the mere pittance of MPG it may save on vehicles, I see no point.
I thought the same. only thing I dislikes so far.
The body, all except the inside of box will be aluminum. The box inside will stay steel. It will have a 8 or 10 speed transmission, I think 10 but can't remember.
I've never liked door mounted mirrors on any vehicle I've seen. The flush to the door style has always been my favorite.
I tried to zoom on the tires....the tread looks like duratracs but I can't see sidewall lugs like the duratracs have
Sent from my SM-G920W8 using Tapatalk
Am I the only one who sees what seem to be four piston front calipers? They don't look like the typical 2 piston design they have used up until now on all full size trucks and suv's.
Sent from my SM-G550T using Tapatalk
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
