4.3 Engine Stall/Surge At Startup
Geiser100
2015 Silverado Regular cab with 4.3 V6. Has just under 14,000 miles. The other day after work I drove to the store and was gone for about 15 min. I kept my phone plugged into the charger. Came out, started the truck and it acted like it was gasping for fuel. Almost like starting up an old lawn mower. It then started surging a few times until I hit the gas and gave it some real juice. Then it became normal. This has only happened one time but it scared me. The only thing different I've been doing lately is running E85 fuel. On my 3rd tank of E85. Temperature has been in the high 50s to mid 60s. So not sure. Any input? Was just inspected and had synthetic oil change two weeks ago.
E85 has a tendency to have this waxy substance build up in injectors and the high pressure fuel pump and at the metal screen at the bottom of the fuel fill tube. His can sometimes create a stumbling idle. Now, once the wax is there, there is no way to clean it. You would be looking at part replacement. I’ve worked on a ton of vehicles that have had this issue, particularly ones with low miles and are around a year or two old. I would never run E85 in anything, even if it supposedly E85 compliant.
Interesting. I've heard conflicting stories on E85 after a quick search. Some say it will clog injectors. Others claim it will clean out your engine better than any fuel additive ever could. The only place that sells E85 in my area is Sheetz. I was planning on going back to gas this month and throughout the winter months, then going back to E85 once it gets warm again.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
