I need to order this Harness Jump Seat to Full Center Console Retrofit  Plug and Play
I have 2018 Chevrolet Silverado. I have the full Console I need just Harness it does have the three USB port on console
Thanks Mike
I have power to all the ports, but no media ability in the console. I have the wire going from the green port on the HMI to the input on the USB. The plug I have would not fit in the black port. In the video it seems like the green and black port are just power ports. Do you know which each port does individually? There is a plug in the black port that is no longer in use. Should I use the black port only for the console? Green is only for the glovebox? Thanks
Just tried the AUX input and it is working, just not the USB ports. All have power but will not play to radio
Also the wireless charging pad does not charge my phone. But that could just be my phone. Not 100% sure about it. Not a need really, I just like everything to work.
Edited by Swagfu
This is the preferred method of USB cable routing.
Thanks. Will give this a shot soon. So should I be able to use USB ports for music in all the USB ports?
Yes.
Working on my 2016 WT center console install.  It has the IO3, I think I read somewhere that it doesn't have the HMI Module at all, is that true?  I already pulled the harness out of my jump seat and swapped out the USB module inside the center console with the one from the jump seat.  So right now I have both the cig lighter and USB/3.5mm working under the lid as well as one of the cig lighters in the front.  Is there a place to plug in another USB on the IO3? I'm also wondering if the power connector is neccessary?  Shouldn't the USB just work off bus power?
IO3 doesn’t have an HMI. So you only have one usb output feed available / which you are using. USB ports are actually a USB hub. Which means it needs 12V and a usb cable data feed.
Thanks! That is what I was afraid of. I think I am going to forgo all the front connections.
I wonder if I can fill in and wrap that front panel or 3D print a replacement panel that is just flat.
Plug and Play Harness by PGAMBOA
For those of you looking to swap your Jump Seat to a Full Center Console, I now have a Plug and Play Harness for this upgrade!  This long awaited - PnP Harness will allow you to EASILY perform this upgrade.  NO cutting or splicing needed!
Center Console - Plug and Play Harness is $150 Shipped anywhere in the US. For Canada, please add $24.95.
Since there are several versions and configurations of center consoles and truck trim levels, I feel that I have covered a majority of the configurations that are out there.  There will be several assumptions on the ability to perform this upgrade and I’ll try to be as detailed and comprehensive as possible.
Please see the different USB Cable configuration diagrams at the end.
Assumptions:
- 2014-2015 Center Consoles will have different USB Cable requirements than 2016-2017 AND will have different USB Hubs.  The PnP Harness should be compatible, but you MUST verify the connector under the passenger AND the front of the console!  Since this is a custom product, there will be NO REFUNDS on it.
- Center Console MUST have its factory harness intact and not modified.
- Connection under the Passenger Seat AND Front of Center Console must look exactly like the diagram.  There is a variant X314 Connector under the seat, so yours MUST match in order for this harness to adapt.
- Additional GM USB Cables must be purchased separately (based on your console year) to get USB Hubs functional.
- Wireless Charging - Wireless Charging became available on 2016 and 2017 consoles.  If you are looking at adding a Wireless Charging Lid to a 2014-2015 Console, please PM me for requirements.  Also, there are known issues with 2016/2017 Consoles with the Wireless Lid and charging iPhone 8 and iPhone X Phones.  There are workarounds for this that require some form of modification to the charging module.  You can also swap the module for a 2018 Module that DOES charge iPhone 8 and iPhone X phones.  Please PM me for questions on specifics.
- Your truck MUST have an existing 110V AC Outlet AND (1) - 12V DC Cigarette Lighter Plug as you will be reusing those.  My PnP Harness DOES NOT add the 110V AC Outlet if you don’t already have it.  However, I CAN add an additional 12V DC Outlet connection if needed.
- USB Cable connections will come from your HMI (Behind the Glove Box).  You MUST verify that you have the USB Ports available, otherwise, your USB Hubs will not work correctly.
- This PnP harness DOES NOT add any Car Play, Apple Play, or Android Play functionality.  If your truck did not already come with it, you will not gain it.
With this PnP Harness, you ***should*** have ALL the components in your console functional.
Those options include:
Front of the Console:
  • Front - Left USB Hub (Dual USB - 2016/2017or Triple USB Hub 2014/2015 - Uses my Plug and Harness AND a USB Cable from the HMI
  • Front - Left 12V DC Cigarette Lighter Outlet - Uses existing connections (truck must be equipped.  If not, I can custom add this if needed)
  • Front - Right 12V DC Cigarette Lighter Outlet -  Uses my Plug and Play Harness
  • Front - Right 110V AC Outlet - Uses existing connections (truck must be equipped)
Inside Storage Compartment:
  • Inside - Left 12V DC Cigarette Lighter Outlet - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
  • Inside - Right USB Hub - Uses my Plug and Play Harness plugged in the front main 42-Way Connector and USB Cable
  • Inside - LED Lamp - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
  • Wireless Charging Lid (2016-2017 only) - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
Rear of the Console:
  • 12V DC - Cigarette Lighter Outlet - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
THERE IS A LOT TO CONSUME HERE, SO PLEASE PM IF YOU HAVE QUESTIONS ON THIS.  I WANT ENSURE THAT YOU UNDERSTAND ALL THE REQUIREMENT FOR THIS RETROFIT BEFORE PURCHASING.
16-Pin - Plug and Play Harness
23-Pin - Plug and Play Harness
Do you have any way I could contact you, I have a couple questions?
Yes - HarnessDR.com. Use the “Contact Us” option.
Only thing I do not have working is Apple Carplay from the USB inside the console. Carplay works from front of console. @pgamboa didn't I read somewhere there could be an issue with Carplay from the inside ports?
I don't use Apple anything so that isn't an issue for me. I am just curious why there are so many USB ports really. Can I have USB stick full of music in each one...plugged in all at once....and filter through them in the stereo? I won't have a chance to finish the wiring up until after Christmas (Thanks to working in retail) otherwise I would just test it.
Depends on how you ran the USB cables.  If you followed my video, then that method won't send USB data to the compartment hub.  If you ran a direct usb cable from the Black Port of the HMI, to the Brown Port of the console, then it should work.  If your brown port feed is coming from the front USB Hub, then that is the issue.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
