HI,
I have purchased 2017 Chevy Silverado 1500 in September of last year, everything seem to be fine until yesterday.  while standing at the light with the break pressed, the rear camera picture appeared on the display.  it does not have the the guide lines, just the picture, every time I press the break the camera comes on.  When i come to the stop and take my time to put in reverse, the picture stays without the guidelines even though it is in reverse.  If i Put in reverse quickly, the camera comes on as it should with the guide lines.
I have switched bulbs to LED bulbs with resistors for breaks and reverse no resistors as they do not blink, but it was back in September without any issues so far until now. not sure if that can cause the malfunction or not, but i would think that LEDs have nothing to do with the camera.
I'm assuming that water got somewhere and its shorting out/powering up camera.  its cold here so I did not get the chance to look at it yet.
if anyone can point me to where the camera gets the signal from i can probably figure it out before i go back to the dealer to get that fixed.
Notice below  what gear the truck is in including "R" no guide lines..
thanks a lot..
HI,
thanks a lot..
There is a setting for camera on. Is that the issue?
i've looked at the settings and it only lets you display the guide lines, i have also re-set everything to factory settings and still does it.   =(
Man I never heard of that issue before. I guess the most practical thing to do is to simply change the bulbs back to factory bulbs that came on the truck?
If the problem is still there after that, then the dealer will fix it under warranty and you can reinstall the Led bulbs??
yes i believe i got the in the box, its suppose to warm up slightly in the next couple days, ill look at the connection where the camera harness is plugged in, maybe moisture got into the plug...
ill update after i try that....
UPDATE......
I made an appointment to the dealer for oil change and i was going to mention about the issue, but i figured that i better remove my LED bulbs from the rear lights.   I started with the reverse lights, i have pulled one of the LEDs out and replaced it  with the original bulb and..... against my believes the problem cleared.
obviously i had to replace the other side as well, but it seems like the passenger side bulb was causing the problem.  It was too cold for me to start switching bulbs (but i will get back to it).  My question is....  why would the bulb cause the issue after 4 months when it was not even energized unless the truck was in reverse, so it should not effect anything.  I'm assuming that one of the diodes burned and somehow there was reverse voltage feed to the camera..  don't know, but ill look into it when it gets warmer..
the LED in question is:
https://www.amazon.com/gp/product/B01LX4FMD1/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
My problem is that I have a faulty tailgate led light strip thats plugged into my 4 pin trailer connector which is causing my reverse camera to turn on
I'd have to say, this is a bit of a strange thread. I can't think of a reason why replacing a bulb would mess with a curcuit that's connected to the rear camera... hmm.
I hope it was an easy fix
not sure why but all o have to do is put the original reverse bulbs and problem went away, i still have LEDS in break-lights and that is not causing problem for now..  not sure
  • 11 months later...
I have the exact same problem.  Just started today.  I have led reverse bulbs, now I am wondering if they are the problem.  They are Phillips and have had them for over a year now.  Also have LTZ taillights, hope they aren't the problem
Found out the problem with my camera coming on when I hit the brakes.  Turned out to have nothing to with the LED lights.  Found water in the plug behind the rear bumper for the left hand taillight.  Cleaned out the water, cleaned up the connections, applied dielectric connectors grease to connections.  Everything works great now!
Bringing this old one back. Im having this problem now too. Anyone else ever have this and resolve it?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
