For anyone interested I believe I will have the ability to do programming very soon. I have made quite a bit of progress and hope to have the reprogramming method refined and ready within the next few weeks. Please stay tuned. You won't wanna miss this ;)
  • Like 13
yeah...cause no ones interested :P
Yeah, not like I haven't been checking this thread a couple times a day or anything...
Sounds good and good luck. I’m hoping that you’re able to just program the radio and it will work instead of having to also reprogram the HMI along with the radio.
I`m hoping that will be the case as well. I`m waiting on some hardware to come in. I will commend the people offering the programming, it is certainly not easy. There are a lot of hurdles to get over and there is quite a substantial initial investment for everything that`s required.
I`m just waiting on a few pieces of hardware to make their way up to the great white north and by the time I have them I should be able to finish my testing. I will continue to update the forums with my progress. Thank you all for following along!
In the case that both need to be programmed together I`ll be happy to offer the viewers of this thread a 2 for 1 programming for their patience.
I too have a dokus programmed HMI so I`ll be able to tell without a shadow of a doubt if both units need to be programmed together or if we can program the radio independent from the HMI. Cheers!
Edited by th3magpi3
added information
  • Like 7
  • Thanks 2
Don’t recall if this has been mentioned, but I stumbled across this by accident. So the three obvious ways of summoning Siri do not work (home button, touch screen button, and steering wheel). I did discover by total accident tonight that “Hey, Siri” does work. I get the audible chime, but still no voice feedback. I can say “Hey, Siri give me directions to work” or “Play some metal” and it works, albeit a little slow. I will experiment some more tomorrow to try and determine how far that can work and what mic (phone or truck) is being used.
Also adding to that, about a week ago, Siri turn by turn played through the sound system for one short trip. I got excited, but haven’t been able to duplicate that since, but it gives me hope. Today, it would lower the music volume at every turn, but no directions were audible.
I think I may have the solution to the no audio issue. It seems that Apple CarPlay has THREE volumes. One for Siri, one for Navigation and the other for music or maybe that was Phone. Let's start with Siri. Do something to make Siri reply to you. Try to make it something that will make her talk for awhile. WHILE she is talking, turn up the volume on the radio. It must be exactly when she is talking. If you don't get it just right, you will be changing the radio volume, not Siri. Another suggestion is to adjust the volume controls on your phone. In navigation try the same thing. I have also read that there is a setting in Apple Maps for audio. The settings if I remember are: No Volume, low, medium and loud. Someone else solved their issue by resetting the phone while connected to Carplay.
All this applies to Android Auto too.
The problems I have been reading in this thread are issues across the board with many other brands. It is issues with Carplay and Android Auto. NOT isolated to our trucks.
Do a web search about this and you will find pretty much the same. I used Siri no volume Carplay as my search terms. I don't have time right now to expound on this right now. Gotta run.
Well I installed my dokus HMI. No problems there. However the USB port that I purchased must not be compatible with AA. I have the projection icon, but when I plug in and turn on AA, I get nothing. At least it was only $20 for the port.
Sent from my SM-G935P using Tapatalk
Woody, what was the part number of the usb connector you purchased. Also, do you have Android auto installed on your phone? You need to download it. A lot of people think it will just work when they plug it in like carplay does.
Sent from my Pixel XL using Tapatalk
15 minutes ago, woodyfriedt said:
The USB part number is 13509942. Yes I have the app downloaded.
What trim is your 2015? Do you have a center console? What cable are you using, OEM, aftermarket cable? What kind of phone do you have?
Let's try to get this solved for you.
It is a LT. I have the jump seat console. That is the USB I replaced. I used an oem and an aftermarket cable. I have a Galaxy S7 edge. My phone worked with AA in my mother in law's Buick, so the only thing that I can think of is that I bought the wrong port. Or does the battery need to be disconnected and reconnected?
Your comment didn't go unnoticed! Just doing a bit of research on the subject, and while YES, AA and ACP do have different volumes based on the task at hand, the problem most certainly lies in the module not being compatible rather than there being a software issue.
I ran some tests to check out the fixes in THIS THREAD that I found when I Googled the issue you suggested.
Unfortunately none of them worked. Furthermore, to be more convinced it's the module and not the device, I can unplug my phone and plug it directly into another car that has AA and everything runs and plays fine, I'll unplug it and put it into my truck, and nothing. I tried adjusting the volume knob during a song, using the steering wheel paddle volume controls, Spotify volume controls, android volume. Nothing.
Looks like we need to hold out for the radio module programming.
Edited by th3magpi3
Nope you have the proper receptacle.
2 things I can think of. First verify the time on your radio is correct. If it's not, Android Auto will give you an error.
Second, if the LT without the console has a secondary USB plug (I'm unsure, I haven't worked on that model yet), try plugging the device into that. I was able to get AA to show up in projection at the very minimum using the stock USB plug. If there isn't another USB plug, try swapping back in your old USB plug and test.
Some other things to try - Get an iphone and plug it in to see if carplay shows up. I'm sure you know someone with an iphone.
Also, is your phone charging when you plug it in. Does the aux input work? Can you play audio over a usb stick?
Keep us posted.
Edited by th3magpi3
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
