2017 Duramax get back in after driving it will not start turn the key dash lights come on but will not start (no click) takes about an hour then it will start has left me stranded six times since last summer. GM can’t find anything wrong (no codes) they return it does it again very frustrating. Anyone heard of this ?
Edited by Flyingwhiskey
Take a video of it next time it won’t start.  Call the dealer and request a tow.  Show the dealer the video.  Tell them you will pick it up when it is fixed. Contact GM and open up a case on the issue.
Did you happen to try a jump after it didnt start? Its possible the dsah could light up but not enough battery strength to turn over.
All ready done the Video showed them they weren’t to interested. Battery’s are fine because it does start after sitting. The trouble is GM won’t throw parts at it because they don’t get paid for them unless they can prove a problem with said part. I might get my Lawyer to send GM a letter explaining the liability I almost froze to death one night when it wouldn’t start had to go into a store to warm up.
Flying whiskey- You need to tel us more. Does it click when you turn the key- crank slow or not at all.
Document this all.
The starting circuit is seperate because of the amps. Is it happening with BOTH keys?
Back in the day it was sometimes the switch on trans gear shifter not detecting it was in park or neutral.
Wiggling the shifter while holding the key would sometimes do it.
  • 5 months later...
I found that the connections on top of passenger side battery need to be lossened and moved and tighten back up there are 4 connections there to do this to
when truck won’t start I go and do this and it starts right up or it seems to reset after awhile very frustrating problem with such a great truck
Do you have a remote start? does that work? In fact that could be part of the problem - newer trucks with or without remote start have the capability of it. So you don't have to hold the key in the start position-- just spring it there for a second and let off.
I would also try a different dealer or call GM directly
My 2015 Chevy 2500 Duramax just started this shit today of all days. Moving day. Both keys won’t work clicks won’t start. Gauges geeking out and screen being weird. Both fobs won’t work. Tried locking unlocking from outside and remote start with both fobs won’t work.
Edited by Yvonne
  • 3 months later...
I have a 2015 Duramax, anyone find the problem yet? Cause mine just started the same shit! Left me twice last week. Last time I had to have it towed. It finally started again two days later.
  • 3 months later...
2020 2500HD AT4. Mine has happened 3x and the last time it would not start so I had it towed to the dealer and of course it started once there. The 2nd time I was able to start it in neutral and drove it to the dealer. No codes have been active either time. When it is happening I cant start it with the FOB either and I have tried both FOBs, but since it goes through the whole process except for turning over I assume its not a FOB issue. Also when trying to use the FOB I can hear the fuel pump prime and a couple of other noises from under the hood but again no cranking over. Mechanics have mine now again and hoping to replicate but no luck so far. They wondered if it could be related to the glow plugs or something, but its 90+ here and its only happened in the past couple of months so its been warm. Supposedly my dealer has opened a case with the GM department that deals with issues known & unknown. When they try to give it back this time Im going to discuss options for GM buying it back because if they cant find an issue and it resets before the tow truck gets there its BS. I do have it on video but it shows nothing there are no lights, codes etc. This sucks having a very expensive POS that may strand me at any moment.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
