Heads up Display Chevy vs. GMC
I have a 2019 GMC Denali Ultimate.  I believe I have the most up to date software in 803.  I was at my Chevy dealership with a friend and he was driving a High Country and I noticed the Heads up Display showed audio information and other information when changing channels, etc.  My Denali does not do that and I wondered if anyone else knew or saw that the same?  Not to say this bad, but would the Silverado have additional features the Sierra would not?  I can't believe the Denali would not have "all" the possible features considering one is paying more for it, but from what I have seen, this information is not shown on the GMC's.  I have brought this item up previous as those features are shown on GMC's website when advertising features of the Sierra and mentioned it to my dealer but they say there is no way they can find out from General Motors.  Can anyone confirm if their Sierra/Silverado shows audio information on their Heads Up Display?  Thank you in advance.
I have a chevy High country and it doesn't show any audio info in the heads up display. I think GM is bad about not making all of the truck with the same software.
I would guess that the truck on the lot had an older software version.  I believe people mentioned that feature going away a few software updates back.  Not sure why they took it away but 803 shouldn't have it
My HC will show the station in the HUD when I use the steering wheel controls like previously mentioned.
Is there a way to add the HUD to an LTZ?  I already get the red light notifications on the windshield.
2 hours ago, Parker Somerfield said:
If you change the song with the steering wheel, it should show up on the hud.
Edit: I have an AT4 and that's when it shows up on the HUD for me. Also had a 2016 Camaro and the HUD worked the same way.
Agree.  Our 2018 Yukon works the same way but can’t understand the irregularities and inconsistencies with GM.  As I see it if the High Country and AT4 have it then the Denali should as well.
My LTZ also works this way.
And for some reason my LTZ doesn’t. I feel like we’ll never get to the bottom of this...:smash:
Never has worked on my AT4. Before or after the version 803 update. I did finally find out that turn info from the Nav would show up so I guess it's not a total bust. If I remember correctly the GMC site was listing the tach as being part of the HUD at one point. Don't know if thats still listed on the site or not.
It does still show listed on the website.   Those that have the audio line showing on HUD how long have you owned your truck/what is the build date?   I wonder if there was some update at the factory and if it is something the dealer can flash?
My best guess is it was a reverse update at the factory and they took it away. The one guy I know who has radio displayed on HUD has an 8/18 built HC. Mine is a 10/18 and has never had it radio up there. The other trucks I’ve seen it on were from guys who were also early adopters and probably early build trucks.
My LTZ show audio when you use the steering wheel buttons to change station or song.  Display doesn’t stay on, show for short time when you hit button.  It is a 1/19 build.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
