Time for Tires
Hey All,
   As the title states, it's about time for new tires on my 2017 GMC Sierra 1500 SLT Z-71.  It is bone stock and I will likely keep it that way, for now.  The Goodyear Wrangler SR-A tires have been serviceable, but I will not go back with them.  Looking for All-Terrains with a decent tread pattern, load rating, and relatively quiet.  I know that a lot of folks like the BFG T/A KO's and I had them on a previous truck and they did not do well.  Heavy, loud, always out of balance and ride quality was poor in my experience.  They look great, though. I replaced those with Cooper Discovery AT3's and was pleased. I have not seen many GMC's with those tires?
I am looking for 275/55-20 and would like to stay under $1k, but closer to $800.  I drive mostly on paved roads, spend most of the 3 month hunting season on dirt/gravel roads, and occasionally tow a 24' bay boat (~4k lbs loaded down)
Advice, input, experience, and pics are much appreciated!
Thanks in advance!
  • Replies 45
255 75 20 ?
That size does not exist as far as I can tell.
I think you are looking for 275 55 20. My preference would be the Michelin Defender LTX MS $210 each at Discount Tire.
My second choice would be the Bridgestone Dueler LTH $189 each.
Both of these have a 70,000 mile rating.
Since you want an all-terrain tire that is relatively quiet, I'd see if the new Hankook AT2,  Bridgestone Dueler A/T Revo 3, or Yokohama G015 are available in that size.  Tire Rack or Discount Tire Direct online.
16 minutes ago, dieselfan1 said:
255 75 20 ?
You are correct. Sorry about the typo and thanks for catching that.
Michelin and Bridgestone were both on the short list, so glad to see those.   Hankook's but saw some mixed reviews and was a little turned off by those because of the negative reviews.
 I will also check out the Yokohama's.
Thanks y'all! Keep the recommendations coming...
I'm a huge fan of the Cooper Discoverer AT3. Quiet, Great tread life on my old truck and great traction for plowing snow. The new set I'm running only have a couple thousand miles on them. I liked them enough to buy again.
There's a couple of us here with the Cooper Discoverer AT3 4S tires. Here's my initial thread when i was asking about them.
https://www.gm-trucks.com/forums/topic/214819-cooper-discoverer-at3-4s-size-question/
I had an issue about a month ago where I noticed some unusual chipping on some of the lugs on a couple tires. After taking it back to the shop I get my tires from, they thought it was weird and wanted to ask Cooper about it. So, they made a phone call and Cooper ended up replacing all 4 tires for me.  Here's the thread on that.
https://www.gm-trucks.com/forums/topic/223531-cooper-discover-at3-4s-tearing-in-lugs/
Overall I've been real happy with mine since getting them last fall. Ive got the same size as you as well. If I had to do it all over again, I would do it all over again. ;)
I'm running Michelin LTX AT2 and am very happy with them. Quiet like a Michelin always is and has good traction and a cool enough looking tread.
1 hour ago, dieselfan1 said:
255 75 20 ?
I second the Defenders.  Great tire, quiet.
Cooper AT3 4s would be a solid bet. Well priced in your budget. Does well off road and on, it punches above its weight class. Those will be my next set of tires. Light in P-rating and 14/32nds of trad depth with an excellent warranty and track record. Plus they are made in the US by a US manufacturer. After having more aggressive AT tires and realizing how much time I spend on pavement (only occasional back country trips) these tires are right up my alley and can taking a beating and pull through most stuff to boot.
Tyler
3 minutes ago, SkiDooNick700 said:
 Falken Wildpeaks AT3W!  Haven't had them long enough to give long term feedback though.
That is a much more aggressive hybrid tire (more aggressive than the BFG's) and about 10lbs heavier, he would want something less aggressive...
Tyler
Went with the Nitto Terra grapplers. Have an aggressive appearance and the road noise has been minimal. Of course I have a Borla S type exhaust too that may or may not be masking some of that.
Tyler
In a 275/55-20 like he is looking for, the Falken Wildpeak AT3W is 7 pounds lighter than a BFG All Terrain KO2. The Falken is a 6 ply while the lowest rated tire in the size for KO2 is D, or 8 ply, more plies equals more weight.
Michelin Defender (quieter ride) <- currently installed or AT2. (good ride but are a little heavier)
I tow as well.
no other brand offers great ride and long lasting quality, most tires start out ok, as they wear grip and stopping distance suffer, had a set of LTX's go over 80'000 on my old truck.
I was a long time Discount Tire employee (younger years) and Mercedes Benz tech, seen a lot of tires, seen them through out their varying lifespans, no tire beats Michelin from start to finish, they dont cost more, they cost less, b/c you can easily have a set of outlast 2 sets of stock good years. Once you buy Michelin you wont buy anything else.
watch this... in the end, Michelin won pretty much every category, which goes against his title.
x2 on the Hankook AT2, I have them in 275/60/20 on mine and they are nice looking / quiet / super smooth.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
