14 hours ago, Basketcase said:
Specs on truck? Or wheels?
Wheels and Tires
On 10/7/2019 at 9:59 AM, Chrisw253 said:
Wheels and Tires
Method NV HD 18x9 +18 wrapped in BFG AT KO2 35x12.5r18
I have 1.5" spacers that I may throw on just to see... but everything is difficult right now since I broke by ankle pretty good last week, so I may not.
Did you try the spacers?  Just wondering if they clear being pushed out that far.
Super nice, congratulations. I wish I could put that grill on my LT... whenever I get it...if ever..lol. I will be putting on the LTZ grill though, that will bolt right up, gotta love the chrome ????
Thanks!
I would think you could put the HC grill on a LT truck, it looks to me like it would probably bolt up fine but you would need to get the body colored plastic trim piece that runs below the grill and then wraps around up the front of the fenders.
I just wish I could replace the middle bar with the "Chevrolet" for the one with a bowtie.
On 10/23/2019 at 3:11 PM, MrChips said:
Here's my new High Country 2500HD Duramax.
Love your new black 2500HD HC Duramax and was wondering if you'd be so kind as to post a pic of the weight sticker on the driver door jamb showing the actual payload and towing ratings for your truck.  I'm undecided on ordering a 2500 or 3500 and would like to know the actual ratings for an HC rather than the ratings for a base truck on the Chevy website.  TIA!!
Honestly, I really like the look of Chevrolet boldly printed across the grill.  Something different and to me it really makes the truck look tough, which we all know it is.
I really like this truck!
Just my opinion.
Here you go, I took a couple of pictures because the sticker is hard to get a good shot of as it's in a tight spot.
Just my opinion.
I agree, it does look tough.
Thanks very much!
My 2500 AT4 HD has the same ratings. I have the heavy duty front spring. Gets you extra payload. Can’t recall now how much. Maybe 500lbs.
Thanks very much!
My 2500 AT4 HD Duramax CCSB has the same ratings. I have the heavy duty front spring. Gets you an extra 700 lbs payload.
I don't think heavy duty front spring should increase your payload.  You are just going up one torsion bar size which increases your FGAWR 400 lbs.  The GVW is supposed to stay the same.  Your payload should go down a few lbs due to the truck being heavier and gvw being the same.
#iworkforGM
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
