2020 Onyx Black-on-Jet Black GMC Sierra 2500HD SLE Crew Cab - Cloth Front Bucket Seats - Long Box - 4Wheel Drive - "L8T" Gas
Moto Metal 20"x9" wheels with +18mm offset: Model MO993 HYDRA Part# MO99329088218 Chrome eight point star, deep lip design with red inserts
BFGoodrich T/A KO2 285/65R20 127S E1 BSW tires
N-FAB podium stainless steel side steps: Part# #HPC1980CC-SS
Highway Products truck bed rails
first post, thought I'd share my truck. You can't order a 3500hd reg cab at4. So I decided I'd make one. So far it has cognito level/ fox 2.0 / pisk/ 1in rear blocks. Fuel covert bronze 20/10 -18. When warranty runs out it's gonna get serious..... Built many of hot rod truck/car. My last fun truck was a 08 Silverado LY2 4.8 with procharger/cam/headers/4.88 gears. So I look forward to dwelling here and reading many good posts, thanks for having me.
On 8/23/2021 at 3:09 PM, Kjduvall said:
Old fun truck. Cops loved it....
I like what you did to the newer one.  it would be cool to see single cab short bed offered by GM like this older one you had.  Cool rigs.
This is cool man. You gotta go visit 0fx2gv Instagram or website and complete this build!
Looks great!  Nice to see some chrome, it seems every truck on the road has black rims now...all starting to look the same!  I just swapped my black rims for chrome to stand out a bit from the black wheel crowd...That said, I still like black wheels, just wanted a change.
Great suggestion, I looked at there AT4 emblems. And they are nice.
On 8/21/2021 at 11:06 PM, 2011Chevy said:
2500hd LT 6.6 gas with 3” super lift on 37s, bilstein shocks, tint, ranch hand brush guard, rough country hd2 steps.  Really liking the gas burner, it’s a big difference from the 6.0
Nice. What did not do do the MPG with the mew 6.6 gas and bigger tires? Wanting to do something similar with 35” tires thanks
Thank you.  I could not tell you what sort of mileage it got in stock form, as I had the suspension work done and tires installed before taking delivery.  I never even test drove it in stock form.  The one or two times I’ve hand calculated it at fill up, taking into account the trip discrepancy due to larger tire, it was around 12mpg.  About what I expected.  I have no complaints.
Edited by 2011Chevy
  • 3 months later...
The standard cab lifted looks great.
I just took delivery on 1/7/22 of my  3500HD Duramax SLT.  I'll be leaving it stock as I haul a fifth wheel and height would be a concern.
First off, damn nice truck you have there. Evan with no lift you could always put some nice wheels on that. Not saying the stockers are bad but it's nice to have a unique look that's not like the rest.
new here bought it new Dec 15th 2020  LT gasser, put it straight to work towing my trail rig around pulls great
22 pacific blue. Looks black in certain light. Too cold to start a big truck to just core a bin.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
