Hey all, I have a 2019 trail boss with an awful noise anytime the rest suspension is used (all the time because you know...)
I took it into the dealer and they "fixed" it with some grease.. but that has negative side effects, also it already wore off. So yeah.
I just don't understand how this is even a thing. My 2013 didn't make any noises like this. My 2019 sounds like a 20 year old rust bucket.
I went on Twitter, but now I question their ability to do anything. They are just going to tell the dealer to regrease it.
Anybody else have this issue?
Holy ****** that is loud. mine has got squeak as well but not as loud.
My 18 sounded like that, grease was a temp fix and tightening U-bolts did nothing. I finally did the bicycle inner tube fix and the noise never came back. Search for it somewhere on the K2 forums. Cheap, easy (watch your fingers) and effective.
  • 8 months later...
On 7/21/2020 at 8:48 PM, silverado990 said:
I have the same exact problem with my 2020 Chevy Silverado 2500. It did not make the this noise when I bought it. Then after taking it to the dealer for another issue, The service rep mentioned a TSB regarding improper torque on my leave springs. They go ahead and retorque and all of sudden I have the noise.
CHEVROLET TSB #20NA022
2020 CHEVROLET SILVERADO 2500
I have this problem, and I’ve come to the realization that these trucks are trash.
I have 23,000 miles on my 2019 silverado LD and I’ve had SEVERAL issues, i.e. emergency brake light, water pump failed at 15k, squeaky brakes (2 dealers said the sound was normal, Lol), and now the clunking under the bed just started when doing slow parking lot or driveway maneuvers. Maybe it’s the leaf springs? It happens while turning the wheel over little bumps in my driveway. It’s loud enough, but I’m afraid the dealer will tell me it’s normal again. 3 year warranty just expired.
Here’s a question - if I trade in my truck will they ding my trade-in price since it has so many noises? I would think not since GM said these sounds are “normal” but we all know sales and service are different animals. I’m wondering if I should demand a letter in writing from the dealer that says these noises are normal?
I could never sell it to a private buyer like this…wouldn’t make it out of the driveway before they’d hear the clunking sound and squeaky brakes. Also it’s an asphalt princess. I have not abused it or modified anything.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
