I own a 2020 GMC Sierra 2500HD gas 4x4.  As with all GM trucks of this type, the chassis was dipped in wax to protect it from corrosion, however over time, some of this wax peels away ( or is chipped away), then surface rust appears.  Left unchecked, the surface rust takes over, and the next thing you know, you're looking purchasing a new truck.
Two questions:
1.  What methods are used to clean and stop the surface rust?
2.  What products are used to recoat the chassis following the removal and remission of surface rust?   Is there a compatible wax undercoating available from Bodyshop supply houses, or do we simply use off the shelf spray can undercoating (will it stick to the wax)?
This isn't exactly the correct product but it's all I have laying around but I use bearing and axle grease and pat it on the bare spots. You can buy aerosol cans of the factory wax but that ****** is like 60 bucks a can.
Daubert NOX is with that manufacturer uses.  I purchased a few spray cans of the stuff when I purchased the truck, and I use it occasionally to touch up parts of the frame where the vehicle lift contacts it.
  • 2 years later...
Even if we recoat the chassis with the correct wax type product, we still have the issue of surface rust and how to deal with it.
My initial thought is to power wash the chassis to eliminate any contamination, especially from road salt.  Even then the bare metal has residual oxidation that must be removed or chemically converted.  There are many OTC products that will work, but my experience is they're only asgood as your chassis is free from road salt.  If you coat with brush on latex or Permatex spray type rust converter, over road salt, you actually make it worse by locking in the Oxidizer.
When does this become an "exercise in futility"?
Edited by Z45
4 hours ago, Z45 said:
When does this become and "exercise in futility"?
Definitely is.
PB Blaster Surface Shield I used on a rusty Jeep frame. I did not do any preparation, and a year later still had good coverage when it was sold. Recommend reading the MSDS and using personnel protective equipment regardless of the product chosen.
First this...
shopping?q=tbn:ANd9GcSR6hWDPCItGJSF0OipLhmZ7xGPabM3S3LLWGZECXXbwjxp3kW8iVUy9AoknEJ3FjAHuVLEQSGgbwToCRL3MeCfufRa4IkwlWoxhkYNQt9bF2FXjkqVzd2r5H0
Then this...
Image 1 - RUST-OLEUM 12 oz. Roll Bar and Chassis Paint
Then apply the OEM wax coating...
IMG_4017.webpmasonk4566 · Mar 18, 2024 at 5:37 PM ·  View media item
Edited by Gangly
  • 4 months later...
I tried 3M cavity wax on my old 2014 Silverado and it didn't help with crap, probably because it was too late when I bought it after it was a lease and the rocker rusted through on the passenger rear at the bottom and the rear wheel wells were rusting through even though I flush them constantly and use the wax coating on it.
My current 2023 is nice and clean and only has a tiny bit of surface rust on the very front upper frame area where it's hard to reach for having it coated and I take it to rustkote for undercoating every fall before winter and it's been doing great. I also pull the wheel liners in the summer and fully clean the liners and the steel then wax it with carnuba wax and touch up on the cavity wax for any edges that are hard to wax. I do have to pay each year for the cavity wax but i'm not happy with the work i've seen done at krown and ziebart.
Rustkote does a great job for me with coating the bottom and inside the doors and rockers, my only complaint with them is they spray the inside of the engine where the cross brace and frame at the top by the radiator sits and it makes a mess of overspray and I just take a old oil rag to wipe up the excess on the plastics. They also try to wash the overspray on the body but it doesn't work and I always take the truck home and hand wash it to get the excess off the body panels and glass. You can hand wash but can't flush the underside and even where I live, the carwash doesn't have any underspray like they advertise so it will never flush the underside out.
AMSOIL's Heavy Duty Metal Protector works great for an undercoating or even touch ups.  I use it on my 2019 Silverado. It doesn't effect the factory coating.  If you want a quote for a couple cans let me know.
https://www.amsoil.com/p/amsoil-heavy-duty-metal-protector-amhsc/?zo=521390
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
