I have been reading all the posts and have found all the info very helpful as I have a 2014 Sierra with the same vibration that most of you have. I have 2000 miles on the truck now got it with 26 miles . Started feeling this with around 580 miles have brought to dealer several times. They have balanced the tires, they have sent out to have tires road forced balanced both did not correct the vibration. They said might be bad tires or rim( good year 20" and polished Crome rims) they said let's try a different set. I said lets get gm involved . On 1/31/14 I meet and went for a ride with gm service rep and sales manger from dealership ,both agreed that my truck has a vibration . With my truck I can feel vibration at 5- 90 mph. 5-30 not that bad but there,35-55 bad on seats front pass, steering wheel and rear seats 65-80 more in steering wheel but still though out truck. Gm rep had a gm engineer come with a vibration analyzer on 2/10/14 to my dealership . Hooked up this computer with a bunch of sensors that gage the vibration. Worked on truck for six hour , checked balance of driveshaft that was good put two different sets of tires on vibration still there with both sets of tires ( one GY one Bridgestone ) stop at dealership after work for update and was able to talk with engineer who told me that it's my rear end that American axle manufactured said lots of problems with trucks with 308 gears.that gm will not be putting 308 in the fifteens only 342 . So he ordered a new one that has been spec out by gm. The dealership received a complete rear end caliper and rotors that they will be installing tommorrow with the gm engineer coming to make sure all is correct on Friday So that's where I stand as of tonight. I will post the outcome as soon as possible. I think gm needs to get involved sooner than later they know these problem are out there don't let your dealership throw parts and tires at your 45,000- 50,000 $ truck . Told gm that if this vibration is still there they can buy the truck back for FULL selling price or will pursue the lemon law.
Good luck to all have these issues and thank you all for your input.
Give it up guys. the fix is not there. It gets worse.
Edited by gdadlow
They don't know what is making the vibration. Or they do and it is an expensive fix. If they wont buy it back I may just do the lemon law as well. Indiana has a good one. Can't concentrate on work when I think about the stupid decision I made when I bought it. Bluetooth and XM went out today. More shop time. Joy joy.
I have 3.42 rear end and I have vibration as well.
I think that both gears have issues with vibration, was told more with the 308 then the 342. I would like to see if people are out there that have had no vibration with there new 2014 chevy or gmc or any other problems talked about on this blog. But that probably won't happen because there out enjoying there new trucks not frustrated like all of us. I read your post gdadlow about bluetooth dropping calls and xm stop working have you ever heard a snapping sound in dash ? Almost sounds like a small stone hitting the windshield.
I did hear pop one time but could have salt form the roads. I have never heard of anyone actually getting their money back. I am trading for Dodge if I can drive it for more that three days in a row. Lemon law would take some time to do. The quicker I get out the better.
Are you trading your gmc in at dodge dealership or does the dealership you bought gmc sell both? If not are you not going to tell them what's been going on with the gmc , history my be on carfax.
They are a Ford dealer in another town. I think word has,gotten through the industry to watch the sierras.
Truck is in shop and it is coming to a head. Problems will be over tomorrow. I will get satisfaction. Life is too short to worry about a truck. Sometimes we make bone head decisions. We try to depend on a brand. Not this time. They dropped the ball and there is no fix. Good luck. I do not want my truck back because it pisses my off just to look at. Used to be when you get a truck you get up in the middle of the night and go in the garage and sit in it..Sorry to say I cant stand the sight of it.....
I think I'm lucky so far, I've only noticed what sounds like a flat spot on a tire at speed, it comes and goes, but no vibration whatsoever, still very smooth. I found a potential source with the large plastic cover beneath the engine rubbing against the frame and wearing the coating off, probably caused by air turbulence created by the front air dam(?), I trimmed it and so far no noise, fingers crossed. I really hope you guys and GM gets this problem sorted.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
