Hi new, to this forum I bought here because I currently have a 2012 Tacoma Sport that has an on going steering wheel vibration/shake issue since new and is currently in the shop being looked at again. My issue the same as what owners are describing here with there 2013-14 1500 Silverado's and Sierra's.
i been so frustrated by this issue that I'm just days away from purchasing a GM
product , but after realizing you guys are going though the same I put the brakes on and decided to sit still for a bit. i'm going to wait to see what the out come is on my Tacoma before I jump ship. It just awful to see that we purchase this vehicles and then have to deal with issues like these, it's a shame that buyers don't have better option's to return , swap or get a quicker resolve. If it wasn't for the consumer these manufactures and dealers wouldn't be in business.
I'm curious if anyone here thinks I should get a GM now or hold off ?
Jon
Jon
I can't speak for others, but it seems that it just might be the luck of the draw,as far as this vibration deal goes. I've had mine since March and have a little over 4,000 miles on it. Honestly, I can't be happier. Truck has been problem free to this point. IMO,I think there are far more good ones compared to the ones with serious issues. Small issues like the V4 drone and the radio reception ( a fix is being worked on) I can live with.
I have had two, neither with vibration issues. Long story short, I love the truck regardless of the first ones issues. It happens, and this forum is where we all talk about it. I would say less than 1% off all the trucks have the issues. That is still a high number though...
2014 Sierra Denali (new)
2014 Sierra All Terrain, SLT (old)
Sent from my iPad using Tapatalk HD
And what do you base that number on? This means that if you go to several GM dealers and test drive 100 new trucks, only one out of a hundred should statistically speaking exhibit vibration problems? Many trucks develop vibration problems after several hundred miles, so even that would be a poor statistic. Personally I think the percentage number is much higher than 1%.
Keep in mind that not everybody perceives vibration issues the same way. Some people ignore it, while some others obsess about it constantly.
Edited by pm26
Yeah I guarantee a ton of people are driving around with trucks exhibiting the same problems and either don't realize it or don't care. But between myself and 2 others I know, we all have 2014's with completely different build dates and trim levels and body styles and all 3 of us have vibration problems. Now maybe it's a simple fix like tires or maybe it's something more significant but if we're going to talk statistics, 100% of the 2014's I've had contact with vibrate. That's too many no matter how you slice it.
And neither of those guys are on this forum.
Edited by Silverado-Hareek
Mine vibrates under heavy acceleration. It's worse with the 33's on it. My '13 6.2 Sierra did the same thing. They said it was the motor mounts, and to let them know if it gets worse. Has anyone else had this type of vibration?
Nothing scientific, just that most that post on here are the same people. In addition I have not found a lot of others on forums with same topics. I have test driven several and this forum was found due to another issue however it helped me do extra tests on my replacement in case I could advert these issues.
But honesty I have not driven one yet that vibrated. Hence why before I was curious of a you tube video to see the effect.
I think that's a typo the '15's aren't out yet. Even if they are now with the amount of work history he's describing he would have had his truck at least a couple of months. I'm guessing he meant to type 14
Well, he's not wrong. The 2015, 2500 are having the issue as well. Maybe, meant to say 2500.
yes my 6.2 does it also, but only seems to do it till about 4000rpm in first gear
Go to this thread and see if this looks like 1% of the people have problems.
http://www.gm-trucks.com/forums/topic/159890-how-satisfied-are-you-with-your-2014-gm-truck/
36 out of 196 hated there trucks or complained of issues, this is over 18%. This number is way to high.
Of the 10 trucks I have driven 3 had vibration issues. Many would not no better or it wouldn't bother them. If even 1 out of the 10 comes back in because of vibration issues than that is just crappy quality control.
That's 18 percent of people on forum not any where near a true number of owners. Regardless no point going back and forth. I hope you all get your trucks fixed as they should
Edited by Trackermi
GM suggest this may be the cure for some vibs http://sandyblogs.com/techlink/?p=3296
Well today i bolted the flapper in my exhaust open and went on a 100 mile drive, the truck ran in v4 for over 60miles of it and there was no drone or vibration in the wheel at all. I think ill be going in and getting the new exhaust put on. It really never bothered me but now that i know it can be completely fixed i just as well do it. It also makes the exhaust note sound a little meaner. Thanks for the link
Edited by Silverado 6.2
I took the truck for a 2hr drive today to the shore. Anything over 75mph I have vibration in the seat, steering wheel, and floor board. I used to have it in the pedal but that went away after a road force balance. I'm calling the dealer again. This well be the 4th time I've had it in the shop for vibration issues. Even tho every time I go they say they can't feel it.
Sent from my XT1053 using Tapatalk
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
