Have you brought it to the dealer ?
Yeah, haven't had time to go back again. They road forced the tires and it helped for about 10 days, then it came back like it never disappeared
so....my truck, 2014 Silverado, double cab, 5.3, 3.42 rear z71 - vibe issues on highway - been to the dealer many many times, changed shaft - changed tires - changed shocks - then shimmed and changed pinion/shaft angle - ... changing the shaft angle helped with the highway vibe, but created a launch vibe - and it was pretty bad( under a heavy foot) - keys would rattle against the column. even worse with a load on the hitch - since im not actually on the highway much I asked a different dealer to put it back " to stock" although the original dealer who shimmed it said the were shimming it to put it " in spec" and they were big shims - so...... launch vibe gone - highway vibe back - and noticed something - at 40 mph or so I have another vibe - a vibe I thought was v4 drone( was there when I originally bought it) - but obviously its not, cause it didn't do it the whole time I was shimmed - and now its back - some seem to be fixed with certain things- but think mine is a drivetrain alignment problem - like a cross member is off a hair from the trans or engine - just wont seem to line up - my 2 cents and experience -
Did you talk to the dealer about a buy back ?
It has been discussed but not pursued. There is nothing else even close to it on the market. I am just hoping for a fix.
Should have did a little more research before buying this truck but hopefully Chevy can fix it. Going to drop it off today.
I’ve driven the truck approximately 1000 miles on all types of roads. From 40 to 55 the truck resonates (vibrates), especially when decelerating, and going downhill. The more you drive (warn up the vehicle) the worse the vibration seems to get. I can feel it mostly through the steering wheel but can see the dash and center console vibrating in the truck when it’s really bad. I say resonate because it doesn’t seem to be the tires although I really can’t tell. Never had tires vibrate like this before. When driving highway speeds 60 to 75 the vibration is less noticeable (tolerable) but still happening. Almost seems like the driveshaft is out of balance or a bearing is going bad.
I've read through several reples and different sites has there been any specific cause for this problem or is it different for every truck?
2014 Chevrolet Silverado Z71, LT Extended Cab, 5.3L, 7k miles
They can fix it or buy it back if they can't , but only if you are persistent enough to force them to do it.
Wow, how many posts and still no cure, I'm raising the white flag. GM doesn't need my future business.
I am pretty sure mine is fixed. Take a look at my last post detailing the repair.
I have put on 250 miles since Thursday and will put on another 200 tonight.
If these trucks are so sensitive to tires, what's gonna happen when you need another set and have to keep going back for RF balacing? Or is it just because the dealers/ manufacturer gets second rate tires on the cheap?
I want some Michelin AT LTX tires or BFG KO2. The only way I would buy these tires now is if I had a second set of rims. There is no way in hell I would swap them out at this point.
There was no preload on my pinion and I think that was the main issue. I would suspect that the rear differential machine that sets these up from the factory is messing up in production. Not only was my preload wrong, they also used the wrong shim behind the pinion bearing. I highly doubt that these are done by hand anymore.
The guy that setup my rearend at the local dealer has been doing this for 25 years. You don't just throw in a ring and pinion. It is a very precise process. I set up two 12 bolts for my chevelle with an old man that had setup 9" ford and 12 bolts for years. Only after about taking the carrier out about 10 times did I get the pinion depth, pattern, pinion preload and carrier preload set right. (on the 12 bolts, not in my 2014 sierra.) The process had to be very similar though.
My point is if you don't get a seasoned vereran resetting up your rear differencial at the gm dealer, it could very easily be messed up.
Edited by OmahaBen
Oh yeah, that's one thing I wouldn't mess with is setting up a rear end without an expert involved. I just pay the 400 an axle for my mechanic at my off road shop to do it
For the couple guys that have theirs fixed, mark your tire and wheel at each one. Mine was "fixed" on Thursday and I marked mine. After the ride home and towing the boat, I have one tire that has slipped almost 10" on the rim, and another just over an inch. Both rear tires. Can't believe how much it slipped.
I'm gonna mark mine before I go into work tomorrow and drive aggressive on the way to work, see if they move. Maybe the wheels are just a tad too out of spec to keep the tires from slipping on them.
Maybe it's just all this raw GM power I'm putting down... lol
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
