The dealer called me yesterday and took the blame on the z71 rancho i've installed !!! If rancho wasen't that good why would gm put them on the z71s? Lol thats a funny exsuses,after that they've calimed that method wheels are not well made :/ wtf
Now they want to investigate issues with the drivetrain :sigh: .
They should start investigating what kind of workforce and quality control is used to produce these parts first.
so my double cab is vibrating and gm has only gone as far as a 4500 dollar trade assist!!!
45k sticker 3 times to the dealer and no fix....
if i was to go for another truck does anyone know if the crewcab sierra 1500 sle trucks with 20" wheels are seeing high numbers of vibrating
Go through lemon law
Update on my truck. They road forced the tires and matched the high spots on the tires with the lows on the wheels or whatever you wanna call it. They were so close to giving a complete new set of new tires but they were all within spec. I need new tires here soon because I'm at 33k miles, kinda upset about that lol
But, I will say, took it for a 120 mile trip today on the highway and so far so good! Stock shocks suck ass time for an upgrade, if it doesn't vibrate again, I'm hopeful lol
They call it vector matching, It's the only thing they can change that can affect the road force numbers for the tires. If they can't get the numbers within spec after a vector match they replace the tire. Les Schwab did it on mine replaced 3 of 4 and got all the numbers below 10, even got one down to 0.
Ah gotcha. So is it just because the tires are actually bad or are these trucks just so sensitive to tires they have to be within a really tight spec to not vibrate the truck? That is, if that's the only issue is tires lol
Makes you wonder how "true" the rims are on these things. I am not sure where most of GM's are made, I haven't looked but the aluminum rims on my Jeep GC has mad in China stamped on the backside. Don't know if that means much either because the Jeep is a pretty smooth ride. I took the day off to do some work around the house and took my truck on the Interstate for the first time since I took my air dam off a couple of weeks ago. It was very smooth at 75 today but I am sure it was just a coincidence!
Update on my situation (2014 Rally 2 edition). Ive been going back and forth with GM and the BBB and GM asked for one more chance to fix it saying they would put their regional engineer on it. I dropped my truck off to the dealer this morning so the GM eng can take a further look at it. I get a call a few minutes ago and the GM eng thinks the vibrations are cause from the exhaust system lol. I didnt put up a fight when they told me that but in the back of my mind I know there is no way that will fix the issue. Regardless, the truck is getting a new exhaust. Ill report back once I pick it up and test drive it on the highway but per our agreement if GM didnt fix it this time we would go to arbitration.
Got my truck back from the dealer with the new exhaust.....vibrations are still there. Not surpised! I guess they figured since they have no real fix maybe the exhaust system was the cheapest part to replace so at least they can say they tried. Moving forward with my existing BBB case, hopefully arbitration is next.
It is easy to spot any problems with rims when balancing the wheels. "Mad in China"? LOL.
I remember years ago when I had problems with my Volkswagen lemon car, a VW service manager told me that they start replacing the parts that are the cheapest and then go from there, meaning they had no clue what was wrong.
i had 1000 lbs of feed in the back of mine Friday. Got a chance to run it up to 75, and it still vibrated. Maybe not as bad as before, but 80%+ of it.
For what thats worth.
Got my vibrator back from the purchasing dealer thurs., they again claim it has no vibration, this dealer is 120 miles from me and GM forces me to take to them instead of my hometown dealer. Still has a vibration, they have now had it 3 times and I also took it to my local to put new tires on, which I paid for. Had the owner of my local dealer drive it today, he agrees there is something wrong with it. I will start the lemon law proceedings next week.
Keep all your service work order copies.
Sent from my SG Note 4 on Tapatalk
Those that had picometer measurements, what were they and at what speed were they taken at. Mine were 9.92mgs @ 71mph. Limit is 10.0, but bmy dealership refuses to test at higher speeds. I'm almost 100% sure its because they know it won't pass.
So anyone with aftermarket wheels and tires experience that they need to have them vector matched in order to eliminate vibration? It sounds like these trucks are just super sensitive to "out of spec" tires (which I know isn't the case for most of yall) in which a regular mount and balance won't suffice
Mine tested at 30+ and according to my dealer when they got it down to 19 it was "within spec". That was at 75 mph.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
