Well, dropped her ('15 Silverado lt 4x4 v6) off this morning.. got in a brand new Loaner 2017 Silverado Lt 2x4 v8 with 7miles on the odometer....
Shakes 2x as bad as mine at highway speeds. Unreal. Not gonna cry because it's a loaner, but I'd be pretty pissed if this was my seriously BRAND NEW truck...
Almost makes me think mine does not have the "Chevy shake" like I thought it did, man... this sucks. I hate it for anyone who has one that shakes this bad...
Good job, hopefully new one is better!! Although if they are not sure what is problem, doubt it's fixed.
I have 2016 for the first 9445 miles it was good, except for a decel vibe I had due to pinion angle from lowering the truck but was livable.
Well now I have the full blown vibration on my truck, local dealer won't do anything since its lowered. I will need to be sorting that out on my own, hopefully can fix it.
Had driveshaft out to be trued and balanced no issues there. This afternoon will remove driveshaft and drive truck as FWD and see what happensDont you
Dont think you can drive it as a FWD. The slip yoke on the driveshaft fits into a seal to prevent fluid from spilling out the transfer case. You might end up with a mess.
Edited by Towerhog
That is correct. You will piss out all your fluid and burn up up the the T-case if you try to drive it with the rear drive line removed.
Had driveshaft out to be trued and balanced no issues there. This afternoon will remove driveshaft and drive truck as FWD and see what happens.
Be sure to video it!!!!
RT
No videos...but it is definitely not the driveshaft.
Not an issue, I'm not an idiot fellas just used some HD aluminum foil and a lot of Gorilla tape and only lost little over 1/4 qt when refilled.
Truck still vibrates...will play some more tomorrow and try to narrow it down.
:(Almost makes me think mine does not have the "Chevy shake" like I thought it did, man... this sucks. I hate it for anyone who has one that shakes this bad...
Any chance of a video of the loaner shaking? I bought a 2017 and curious what a bad shaker looks like, don't have time to go test drive some others.
Thanks
SilvG
I can definitely try tomorrow after work!!!! It's completely impossible to ignore though... all I could say the whole way home is "damn, Id have turned around to the dealership by now if this was my brand ass new ride with 7 miles on the Odo..."
SilvG
Well, that does sound pretty bad!
I was finally able to get a loaner about 10 days ago so I dropped off my 16 with 6k miles for vibration.
I know they have road forced balanced multiple times and replaced all the tires at least once. I'm going to start asking for trade assist now.
Just wanted to know if anyone knows if GM finally acknowledged there's an issue with the shaking/vibration? Mine started doing it at 700 miles. Haven't made my first payment on my truck yet and it's already going in to the dealer because mine shakes really bad between 70-80mph. If I go past 80, it instantly goes away. Very weird. Here's the most crazy thing, if I'm driving in bad/rough roads the truck bounces pretty bad but the vibrations goes away. If i drive on good/well paved roads, the truck doesn't jump as much but the vibrations between 70-80 is horrible. My apartment complex has crappy roads and when coming home at very slow speeds I can feel and hear every little buump on the road. Horrible truck. Was buttery smooth up until 700-800miles.
I have a 2016 silverado custom and i am having vibration issues at all speeds when lightly pressing the pedal. dealer said there was nothing wrong with the truck but they are wrong i personally think its in the torque converter or trans but i am tired of arguing with them
Try another dealer.
how many attempts have you had/ how many days has your truck been in the shop?
Nope, but if you press enough and are persistent, you can get things done.
yes go to a different dealer, thats what I did. My first dealer wouldn't even acknowledge the problem, I changed servicing dealers and they worked on my truck alot
They fix it?
My '16 Denali has 6660 miles on it. Still vibrating after several sets of tires. I'm also in the 70-80 MPH camp.
When it was in last week for another attempt to fix the vibes, they gave me a '16 Crew Cab Regular Box 4x4. Had that running at all sorts of highway speeds and rode like a luxury car. Wheelbase have anything to do with it maybe?
Anyone with a 6.5' bed Crew having the vibes?
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
