Hey guys just a thought. Would it be possible to lift the truck up on a lift, all four wheels off the ground, bring the truck up to speed, get underneath the truck and try and see if anything sticks out as the source of vibration?
I have been mounting a camera in different places and capturing the ride to/from work everyday... So far nothing there sticks out to me as the source. i am going to pull the wheels off tomorrow and check the axles like the video that 07Softail posted.
Has anyone tried running a lower than normal air pressure? I've noticed most of us on here like to run higher tire pressures for loads, mpg's, stuff like that. Maybe if we run factory pressure or little lower than factory that'll smoothen the ride....
I have the opposite experience. I have tried everything from 26-42 and have had the least vibration, or at least feel in the cab, around 37-40. My tires call for 32-35.
Strangest thing... definitely a reminiscent vibration today at 45mph on highway. Once road surface changed, vibe went away. Speed stayed exact on cruise control. Felt... slower frequency... I honestly wonder if the frame and wheelbase and road contact all have something to do with it... but, I'm lifted 6" on 20" rims and 35" Nitto Exo Grapplers, I can live with some amount of a harsh ride, very stiff sidewall on those tires anyhow. For note, even switching to stock rims and tires did not fix my vibe. Only once the driveshaft get balanced with 3 weights near the rear did it ride smooth. Have had numerous folks drive and ride it, they day it rides like a Cadillac, Ill take that.
Also, about 8 standard pallets in the short bed did not improve the vibration on that particular stretch. Other stretches of road that used to do it, do not anymore. the tuning fork effect may have some merit.... harmonic vibration is real... but this is the truck I bought and I am finally happy with it
Not to burst your bubble but many have noticed a short term improvement after their truck has been up on a lift. I am sure they put your's up to pull the drive shaft. Then a few days later. as it settles, it starts to vibrate again. Hope that doesn't happen in your case but just be aware that it is not unheard of.
And no more Tundra for me, I decided to go SUV for awhile so I grabbed a 2017 Sequoia yesterday. I'll beep and wave as I drive by my old Chevy dealers tomorrow lol
Edited by C6Bill
That's a helluva jump in gearing! Hahaa I bet it runs like a bat out of Hell now! How tall are your tires and what RPM's is it showing at 80 mph?
RT
I don't recall my rpm's at 80, but it should be around 2100. However at 70 mph, I am turning approximately 1876 rpm's running 34.3" tires. I can't believe I waited so long to regear the truck.
Hello Bill, Let me know what you think about the Sequoia. Thinking about getting one for the wife to replace her Expedition. When ford went to the v6 in the new Expeditions they lost me. I know the highway mpg for the Sequoia is 17 just curious if it will do 17 are any better. The Sequoia is alittle out dated just like the Tundra but they are proven.
Thanks
MPG sucks like the Tundra, I'm getting 16 but I haven't hit the highway yet. I'd say the faster you go the lower it will go. But it rides great and like most Toyota products it is functional not fancy. Quiet interior with an easy to use NAV system and extremely comfortable seating. I went Limited as I didn't need the DVD entertainment system in the Platinum. But by doing that I still get Blind Spot monitoring but not rear cross path detection. And the rear window goes down just like Tundra so that is an added bonus. Hope that helps, if you have any more questions just shoot me a PM so we don't hijack the thread.
Edited by C6Bill
We know how much RT hates that :crackup:
MERRY CHRISTMAS, HAPPY HANUKKAH, HAPPY KWANZA, or whatever you any yours celebrates!!!
Had all four tires balanced today by an actual tire shop this time. A little less vibration but still has the shake. The steering wheel vibration has decreased a bit too. Oh well. At least I had it done for free. Guy said the balance that the dealership had done was horrible.
Had a bad shake the other day. Truck will run great for weeks, no vibration or shake and then it acts up. Everytime it acts up I consider trading it in lol
Sent from my SM-N920V using Tapatalk
Trying to figure out my vibration every time I'm home. This time I took her out on the road made sure the vibration is still there. It was. So I went into the shop and put the stuck up on stands.
Got it up to speed on the stands and the vibration is still there. Since I know my driveline is not true. I had it spinning at idle and could see the wabble in the driveline. So with a marker I slowly went closer to the driveline and had it mark where the bend is highest. Put a 3" hose clamp 180* from that spot and the vibration almost went away. But is still there. Next time I'm home the driveline is getting trued and balanced. After that I'm going to swap the rear differential from a 2013 max tow truck with the old style 9.5" 14 bolt.
Since every truck that has this vibration had a few of the same parts and manufacturers like drivelines and this new 9.5" hybrid 12 bolt they put in.
I honestly think it's this new rear end. I've seen a lot of guys fix it with a gear swap. And if I'm going to do a gear swap I'm going to put an axle in that's proved itself already.
Truck specs
2014 5.3 l 4x4 crew cab 5'8" bed
6" pro Comp lift
Pro Comp add a leaf.
Air bags.
112d9d10a75ac1869e672b465e4b61ef.jpg34e142a760cb5af0b49daca6664c495e.jpg77fca7ebe46823d8f47c6b749f850b12.jpg12acdd77c92af423f676578aceeff31b.jpg
Sent from my Pixel XL using Tapatalk
Edited by smcgillis10
Driveshafts are bent and missing weights and axle shafts are out of round....watch the video's I posted.
RT
Edited by 07Softail
    • Looking up on the web you can the information that would seem obvious. You asked engine components to do more. You get more wear. The answer is they can last just as long but required more maintenance. Apparently having to change lifters, cam and associated components are maintenance or repairs. In some research the normal life span of valve train components are 80-100 miles with 3-5K miles oil change. So the next logical conclusion would be cost per mile. I use that analogy with my wife all the time with vehicles. My Odyssey is approaching 170K. The cost per mile will go up at 200K with maintenance. Looking at a low cost car. A K-4 with a 10-10 warranty. Selling my Ridgeline that’s about to hit the same maintenance milestone. My argument becomes not only I get worry free driving. But at no cost increases. Because I take the money from my Ridgeline and maintenance savings and other potential savings. I’m driving for free. So tying it with a bow. It makes you wonder. Is this a grand conspiracy by the auto makers? Raise the potential maintenance high enough. Buyers by extended warranty to 100K miles. Do the minimum maintenance required. Trade in at the warranty end. How long should they last? That question is what keeps people up at night. The answer is much more complicated than it used to be.
    • Could you cite your source on this?  I cannot find any reference to the US secretly taking the oil.  I find references that the US helped oil tankers move through the Strait of Hormuz, but nothing about what you're stating.
    • Same thought, also the everything doesn't have the details real photos do (talking about the noise in the photo)
    • Since the media YOU and your buddies are programmed to watch failed to mention this, I'll fill you in.   Trump admitted today that we've grabbed 150 MILLION barrels of oil from the Iranian tankers locked in the Strait by our Navy. We turned off their transponders, took them out to sea in the dark of night since they have zero radar capabilities anymore, offloaded every drop onto another vessel, and put them back by morning so no one was the wiser. That oil has been en-route THROUGHOUT the entire conflict.   Main reason he admitted this is to let even guys on our own side who joined leftists in complaining about the prices that he hears us all, and has taken steps to make sure this didn't spiral into a BAD situation ... just like the mainstream media has been PRAYING would happen, just so they could gloat. Amazes me how these people are rooting for the destruction of THEIR OWN HOME, just to make a President they don't agree with or like look bad! That's next level TDS!   I know your not capable of giving our President the benefit of the doubt, again due to your deep programming, but THIS is why oil never hit $150 a barrel as predicted by your programmers, AND the reason oil continues falling. Like I said before, Trump's got a plan, and this is proof of it. By the end of his term, we're going to be in GREAT shape for a change!   Since I just spent $3,000 this week on #2 heating oil and gasoline, the war most certainly is ending! 🤣   https://mxmnews.com/article/ba359ac9-2711-4851-92de-187f2400f2dd?breaking-trump-cancels-iran-strikes-deal-now-approved-by-all-parties
    • No leaks. Replaced the condenser 3 years ago. Problem was found to be caused by the A/C blend door actuator. Just replaced it and it's blowing out the cold air it used to when I bought it.
