1 hour ago, Barak said:
Yep saw this video and my doesn’t do the same when having a bottle of water in front center console. Again it would be cool to get in a truck that also vibrates to really compare and determine ifan issue exists.
Barak is yours a 6 speed or 8 speed transmission?
Great news. Well keep us posted so we have something to share with the dealership to troubleshoot for besides tires rebalancing and downgrading tire pressure.
21 minutes ago, Barak said:
6 speed...
OK, I wasn't sure and if you had the 8 speed that was a different problem than this one.
Right. Based on all reads and everything I learned about so far, I am still studying it. Reason is while I know this vibration affects 1500s, I am not sure if what I feel is aort of normal for 3/4 ton heavy duty truck and diesel. So I am just curious now about it all and need to explore further.
It's important that your dealership is equipped with a road force tire balancer.
My Silverado's rear tires were found to have over 20 lb each of road force, resulting in two new tires under warranty and no more shaking.
Thanks Don67. What brand tires do you have? The dealership has told me that every time they balance any truck tires, they do it on road force balancer and within manufacturers specs in my case GMCs. However, my dilemma is that when I go there it’s usually some young tech who I feel doesn’t even listen to what my frustration is. They also hesitate to drive the truck on thruway at speeps such as 73-75mph. So far I drove the truck on thruway at many speeds including at 80, 90 and 95. I am shocked to say that only shake/vibration that I am curious about still occurs at speeds 73-75. It’s very interesting! So at this point I feel taking it to independent tire shop and explaining to them the shake/vibration at that speed to see if they will be able to road force, rotate as well and see what they say about the GMCs specs requirements. I just don’t know if the dealership would continue cooperating if I end up going to independent tire place. Thoughts?
The dealer is not going to know if an independent shop RFB’d your tires or not.  If you take it elsewhere and it doesn’t work out, take it back to the dealer and have them throw some more parts at it.
I am going to consider going to independent shop just to rulle rims/tires out and maybe I will learn something new about these Goodyear wranglers from them! After that I will continue with the dealership if vibration persists as I have learned some had ring and pinion replaced per GM.
Got a text from the service manager today. Said they replaced the ring and pinion and there is still a vibration. He said they sent more data to GM to see what the next step is.
Its sad that dealers can no longer troubleshoot problems themselves and that they have to get approval from GM for warranty work. I guess GM's process is done via a flowchart. My worry is where this will wind up at the end of the chart.
This is why I always say that people who drive desks for a living will never understand real world problems or how to repair them.
Lets see what the Professors at GM come back with. Hopefully its a new driveshaft to go along with my new ring and pinion, and new set of tires.
That’s very interesting discovery. Well here is how far I got. So far 2x to dealership first time was road forced balancing second was let some air pressure out of rear tires. At that point I was at 800 miles or so. Now I am at 1300 miles and come to find out shake/vibration is reduced significantly for whatever reason. However in mean time I did reach out to GM corporate and they have now an open case only because I wanted the dealership troubleshoot for 2 service bulletins relative to bent wheel, bad tires and driveshaft turnes. So will be back in for 3rd visit to see what they will come up. I have speculated whether or not it could be something with bent rotor or not properly functioning caliper(s). I have felt brakes to squal as well so now I am just curious. And shake/vibration reduction may have been to rotors wearing off or caliper dead or who knows anymore. More to come.
Sorry for the late response.   I have the OEM Wranglers... brand-new truck just this summer.
Definitely try your luck at a private tire shop.  A good one will be happy to diagnose what the dealer missed, and give it to you in writing.
I was lucky that my dealer recognized the shaking, as it wasn't very severe.   Although I said it was gone in my previous post, I still get traces of it at highway speeds but not all the time.   Not sure this truck will ever feel glassy-smooth.
Ok thanks. So you are getting it here and there. That’s what I am starting to experience now too. No more shake/vibration at 72-75 speeds but felt it little at 77, 81 and 85. Very strange but interesting. I haven’t gone to independent tire shop yet as they instructed me to continue exploring with dealership first due to cost they would need to charge me for road force balancing which would be about $100 for 4 tires. I will be at dealership tomorrow for another look per 2 service bulletins to rule some stuff out. Will provide update. Thanks!
Update: went to dealership per GM to troubleshoot for service bulletins I found which may be related to my vibration concerns. Dealership took vehicle in but told me because it would go thru a PICO test, they weren’t sure if one was available in their shop. I left and 7 hours later advisor contacts me telling me they don’t have PICO tool and one was on order so they will have to call me to bring truck back. I said ok sure. Went to pick it up and truck was parked on lot same exact way I left it meaning they didn’t touch it. Anyway, so next step is PICO test. However, this time I was approached by service manager who informed me that they had a customer with similar concerns and they ended up replacing shafts, drive axles,  etc. So this time I learned that dealership is aware of the vibration concerns and so is GM and it’s now occurring on 2500HDs not just 1500s sierras or Silverados. There you go guys that’s what I learned about this time and what’s next step for me. Thanks!
So they went from "they don't have a Pico available" to "they don't have one at all"? Makes you wonder when they get one if they even know how to use it. Guessing they got lucky replacing the items on the "other" truck. As far as I know 2500's have always been in the Vibration zone along with 1500's. Good luck!
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
