19 hours ago, jscottl said:
Yep that is a little bambi catcher for sure. Too bad once it catches a deer your front end is going to be toast.
So? Not any different than without it.
  • Haha 1
11 hours ago, slj2008 said:
should have a brush guard / led light bar ??
I don’t like brush guards and can’t stand LED light bars.
Had a lot done a lot in the last month or so. Totally new brake system save a few lines, BT Dieselworks autosync, short antenna, APS sidesteps, Morimoto headlights, then had wheels and tires done last week or so. Tried to get Eibach pro truck shocks done today but my lower spring perches are pretty shot so doing Eibach stage 2 kit now. Waiting on good weather to do plugs, wires, tow spec full aluminum radiator, sure-cool valve, black rear bumper, black front bumper, Morimoto fogs, and updated rearview cam. Waiting on parts for DOD delete kit and Circle D converter, also Kryptonite hubs and tie rods to do an offroad spec knuckle conversion with cognito and TTX control arms. When everything mechanical is sorted going to do rust repair/prevention and paint correction with debadge.
  • Like 4
Some great upgrades, looking nice! Are you planning on wrapping or painting the bumpers? I wrapped mine and they look awesome, plus no worries with rock chips like the painted bumpers. 3M 2080 gloss black vinyl matches onyx black pretty dang good.
Thanks. Not gonna wrap anything, but that is good to know about the matching. I have a black steel bumper awaiting install, I hit a deer in my last 1500 so it's a big priority this time.
Today I got to do something unheard of around here on January 12th. I gave the big girl a hand wash in the street. It was 36°F here today.
The fist pic is the foam cannon action , not salt.
Edited by dieselfan1
  • Like 5
I was about to say, that she was in need of a serious wash.  For me to wash my baby during the winter months, it has to be at least 45º for wash-o-matic, and at least 65º for handwashing.
Looks good.
I don’t drive dirty vehicles. I have monthly car wash passes. Up to 3 times a week I go through. Even on trips where I stop each night I’ve located the same type of car washes. Contrary to popular belief no scratches.  A little spray wax about twice a year.
I typically only  hand-wash the vehicles (with a hand wash-mit and cold fingers) and no foam cannon, regardless of temperature.  It's fun in single digits when the soap foam has frozen to the vehicle by the time it gets washed off.  I'll pull the vehicle onto the lawn so as not to create an ice rink in the driveway; the exception was last year when we had a standing 12"+ inches of snow for over 2 months and I couldn't utilize the lawn, so I did have to purchase a monthly car-wash pass to avoid the driveway icing.  The Bimmer's Monacoblau paint did NOT appreciate that, the carwash beat it up good, but swirl marks > corrosion.  During winter, I wash the vehicles in use at least once a week, which is why I'll also limit usage to 2 instead of 6.  Paying for a carwash pass is painful, as is paying anyone to do anything.  I hate wasting money frivolously. 😉
Now, the bow tie on my steering wheel matches the ones on the grill and the tailgate.  Tried using some touch up paint that I had, didn’t like it, so I reworked it with some Plasti-Dip I had laying around.
Prepped for my initial attempt to paint it black.
You can see how “ugly” it turned out, initially.
First of three layers of Plasti-Dip.
Used my recently purchased heat gun to force cure each layer/application.
“Finished product.”
Edited by Ravenkeeper
I’m on a streak, did something else to my truck, today.  TAILGATE LIGHT BAR
A few weeks ago, I connected a 5-Pin Flat Trailer Connector to my Lightbar.  Last weekend, my son and I put all of the wires in a tube, just like the rest of the harnesses under the bed.  Today, before installing it, my son and I tested it, it all worked.
Tailgate Light Bar - Tried catching the unlock flash.
Unlite Lightbar
Connector above hitch
There’s a “box in front of the bumper, where I stuffed the rest of the harness.
Adding photos
95mm+ Soler Performance TB came in! Looks good, but it came with some scratches I wasn't expecting...
Found out they also change the gearing in their tb's so the blade opens 100%. Instead of the blade opening 90 degrees to the housing, it now opens parallel with the s shaped bore. More wot area!
Edited by M1ck3y
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
