Thanks GM for fixing it, 3 days at the dealer for the frame issue and Radio sound problem, the radio still not working after update and xm radio antenna replaced.
It doesn't look like they did much for the frame rust... am I missing something?
They didn't do much, but they call me saying was fixed.
I'm guessing his post is laced with heavy doses of sarcasm. It looks like they painted the pumpkin and that's about it. Great job GM.
Edited by badfnz
You are right.
I'm assuming you've had a follow up discussion with the dealer on the "fix".... What was the outcome?
To the OP:
Do yourself a favor, get some sanding discs, a few cans of black primer paint, and several cans of good quality professional rubberized undercoating and fix it yourself. I would not even bother taking the vehicle to them. You can fix it nicely yourself in several hours and be happy with the results.
If I worked at that dealership, I would be embarrassed to call that fixed. Someone got over promoted at that shop. He is probably related to someone, there's no other way he could otherwise keep his job.
When contacting the dealer, they said TSB #14002A did not apply but #PI0564D did apply.
Does that one say it is NORMAL?
Por makes a rust coating the neutralizes the rust and puts a black coating on it. If mine does it that will be the step I take.
That's not acceptable! Looks like it was done by a blind man. I'd be back there demanding to know why they had the truck for 3 days and that's all they accomplished. I sincerely doubt it's GM's fault, but that of a lousy dealer.
You actually left the dealer with it looking just as bad? I would have no accepted that.
I had to leave on Saturday after 15 minutes of waiting for the general manager. I did had a meeting with him this morning and GM by email. Dealer said he just followed GM directions.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
