2014 5.3 to 6.2 engine swap
07Softail
What if any issues would be involved in this swap as far as ECM's go... I can get a 2014 6.2 and Trans with 52xx miles on the clock and the (ECM) which is almost the miles I have on my 5.3 for cheap.. REAL CHEAP!!
I have driven the truck with the roof cut off (Total Loss) and it has had a RX cc on it since 400 miles so I know it's clean and oil has been changed twice, the truck runs VERY VERY well!
Can I plug and play the ECM and drop the 6.2 in? Will the computer have to go through the learning and cranking process?
It also has the 9.76 axle and has 3.73's which I can get the whole axle assembly for $500 which I am going to get regardless.
I am wanting to do this plus installing a TVS1900 Mag also and can do this well under $8000 including AR Headers. Any engine swap ECM gurus please chime in!
RT
Even if you don't put it in your truck it would be a great engine for a project vehicle
Ryan
I would imagine everything should be able to swap right over. Should be pretty damn close to plug n play!
You will have a badass ride then!
I would think you would just swap it out and then you'll need a tune. You will have to change a few things like exhaust (diff size) and maybe other things like that. Since you'll have the motor out out you might as well put some headers on it.
I was prepared to ask why not just buy a new truck, but with the entry point, sounds like you should do this! I would think you could either reprogram your ECM, or just replace it, no? FWIW, the engine bay has quite a bit of room to work even with the 6.2L planted in it.
Cant get a 6.2L in the Reg cab tho. That is what OP is after.
I just wasn't sure when ECM was swapped that I would have to have the dealership do anything. and yes I will be doing headers and a TVS1900 supercharger also with a BB tune and the 3.73's.
RT
Immediate thoughts are the converter and tuning as differences but with the trans and engine you got that covered. Curious if converter is different, assume it would be.
As far as the ECM, not sure if it is easier to have a custom tuner just flash yours or to swap ECM. Very curious about this though. If you do it, start a build thread.
Oh I definitely will. Leaning towards getting the Engine,trans, for a project anyway and $3000 for everything seems alittle hard to pass up and the 9.76 w/3.73's will be going into my truck regardless.
RT
Yeah that seems like a steal. Gonna have a truck that moves even without a blower.
I would just have the tune in your ECM updated, the ECM/TCM/BCM are all married together to some degree now. You will have a lot less head aches if you just put your transmission behind the new engine and use your ECM and have someone flash your stock ECM with the 6.2L engine tune. Otherwise the ECM/TCM from the 6.2l is going to have the VIN in them from the donor vehicle and I am not sure if anyone has the ability to change that info yet.
Thanks that is what I was thinking but wasn't sure about the VIN# issue. If I am splitting engine and trans I might as well go with a little more converter also. Geez does this ever end? LMFAO!!!
RT
That is a crazy deal for a 6.2, does it include the trans as well? For the ECU, both trucks run the same E92 ECU with different calibrations. As others have mentioned you would want to reuse your original computer and have it setup for the 6.2. Should be a very simple swap.
When I was looking for an LS to swap into my Jeep the old 6.2 and trans with low miles like that was over $10k.
$3k seems like a steal. You almost have to buy it just to find something to put it in. :)
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
