My dealer immediately agreed that the backup camera image on my '16 was hazy, and ordered a new camera which is being installed as I type this.  No charge.  Gotta love warranty!
On 5/4/2019 at 4:14 PM, JayTrailBoss said:
I purchased a new 2019 Silverado Trail Boss on 4/26/19. When I got home, with approximately 20 miles on it, I went to backup in the driveway and the camera became "fuzzy" with lines through it every time I touched the brake pedal. So I tried backing up several times and it repeatedly got "fuzzy" with lines running through the screen. After being in reverse for about 30 seconds or so the screen went blank and an error message appeared "service rear vision system". Within a moment or so the camera came back on however the guidelines for backing up where not there. I tried tapping the screen and hitting the home button but the only thing that got the guidelines to come back was to shift into park or drive then back into reverse. I called GM and they said to bring it to the dealer. I went back to the dealer and was given a loaner (2019 Silverado not the Trail Boss but with the same base package). I noticed this truck did the same thing. The dealer was able to replicate the issue in my vehicle as well as in several other similar model vehicles but stated at this time everything seems to being working "normally for this vehicle" and no issues were found. I find this to be alarming especially with 4 kids who could be at risk if the camera shuts down while backing up. I emailed GM my concern and received a rather generic response so I contacted the NHTSA and filed a formal complaint as this is a major safety concern. It appears that there are postings online about this issue from as far back as 9/2018 but the only thing GM has done is issue TSB's without an actual resolution. The dealer stated the common denominator was the trim level with the "cheaper smaller screen" and that the upper trim models didn't seem to be having this same issue. It would be beneficial for anyone else having this problem to contact the NHTSA with a formal complaint so that GM is forced to fix the underlying problem before someone gets hurt or killed. I was nervous switching from a Toyota to GM and this is my first "American Truck" since 1994 so it's not starting off well but I do like the truck otherwise. Thanks.
Here is the link to file a complaint and the phone number to file a complaint is 1-888-327-4236
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
I'm having the same problems.  I took my truck to have the bed liner and tool box installed. I backed out of parking lot at the dealer all was good.  When I went to back into my driveway a picture of the Chevy dealer parking lot came up.  Then lines came across the screen.  Put in in park and tried again.  The Chevy parking lot came up again then my driveway.  The assist lines were missing and it appears to have water at the bottom of the screen.  Now it's like a permanent image out of focus.
  • Sad 1
I just took the truck to the dealer.  They are replacing the back up camera.  Just waiting for the parts.
I got my 2019 GMC AT4 about this time last month, July 2019.  Two weeks later I was on a trip back from a job and suddenly I got the message “sd card removed” and at that point the nav stopped working and then it will come back and then the message again and the nav will stop. 15 minutes went by with message on and off and  Then I got a blue screen of death.  Complete blue screen with the message “service rear camera system”  the front camera went all foggy and blurred.  Every time I shift gears now I get a blue screen.  None of the cameras work.
I took it in to the dealership when I got back into town and they said they have to wait for a solution from GM and it will take a couple of weeks.  It’s been a week now and I am waiting.
Got the Service Rear Vision System yesterday, after about 15 mins, it all worked again.  Hoping it stays this way.
i've had the nightime bright white screen too, but only happens at night. I'd say the camera is a downgrade from my 16 for sure.
Yeah... I have the 8"screen in an LT All Star Package... Didn't realize no HD camera.. The non HD absolutely sucks at night time. Also... No fog lights and no  Sirius. My 17 all star had them... Why take it away? Pay attention to your window sticker.
Honestly... How much cost difference can there bee between an HD and non HD camera... Everything on the market is HD... This is a poor choice by GM... Watch... 2020 or 31 it will be standard.... And they will play it off like it's something new....
I lease because I don’t put many miles on. Having the same issue on a Sierra SLE. Traded in my 17 Silverado early off lease to get ‘19 GMC on a great deal from the dealer. Has SLE preferred package which used to have Sirius but now doesn’t and I missed when I bought. Also backup camera is unusable at night. My Silverado was excellent at night. Very disappointing to go to this truck and have these issues......
Mine does this too, from time to time.  Screen image is fuzzy, sometimes it blanks out.  What I do is "reset" by putting the transmission into Park or Drive, then back into Reverse and it usually clears it up.  But it has been like this since the beginning.  It's a cheap video system they went with apparently.  Wonder where it was made (the camera and computer?)
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
