When the General Motors and the UAW announced a deal to end the ongoing strike last week, one of the potential settling points was a $3-billion investment in the Detroit-Hamtramck plant for future electric trucks. On Friday, Reuters reported that an all-electric pickup branded as a HUMMER could be the first product out of that investment....
https://www.gm-trucks.com/your-first-electric-pickup-may-be-a-hummer/
What do you guys think? Is this exciting? Lame? Where is GM going with the brand if they do label "Project O" as a HUMMER?
When I asked the finance guy last Friday when I was picking up my baby Duramax what he thought of Ford's electric F-150 commercial and $500 million "investment" in Rivian, he said "somebody has to be first to fail". Guess he didn't get the memo.
I'm guessing $100k starting price. If the average truck is selling for nearly $60-LARGE these days, what's considered "upper end"? $200k?
After owning a couple 21st Century GM products, I'll take a looooooong pass on this one.
They are probably referring to a humm(er)ing-bird lol
so long
j-ten-ner
...and yes, electric truck is exciting, as a Hummer not so...
Edited by j-ten-ner
  • 11 months later...
The electric Mustang doesn’t look anything like a Mustang so I wouldn’t count on the Electric Hummer looking like the original either.
  • 3 months later...
To me this is also one of the problems with electric. Why do they all have to be so butt ugly! With the exception of a few electric cars most of the ones coming out including the GM ones look crazy ugly.
Edited by Likarok
this is not the first elertic pick up truck
GM had the    S10e  in the 1990s they made 492 on them
Edited by bg1988
Have you seen the details of the F-150 Lightning? $40K!! Okay, if you can live with a 200 mile range.
Oh...do you want 300 Miles?
That will cost you an additional $10 LARGE
Tesla just lost a lawsuit in Norway over hindered charging and battery capacity knockdowns with each software update to the tune of 10K vehicles at $1,600 per vehicle.
Let the games begin!
I agree with you! Haha. Harsh but true.
Yes sir!
Had 2 of them.
1 was the Little Red Wagon dragster.
Other one was a GTO.
1 hour ago, diyer2 said:
Yes sir!
Had 2 of them.
HEY what happened to your kitty? He was Boss!
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
