On 9/11/2020 at 2:34 PM, topgear1224 said:
Yes, the fuel tank is on the driver's side
To follow up on this, I was always under the impression you would typically want the drivers side slightly higher than passenger. The rationale being tank of gas increasing weight and the weight of the driver. Too many times it’s just the driver adding weight with no passengers... this weighing down left side.
Edited by Duramax3oh
I just installed these on the rear and yes, there is a huge difference. The rear is a lot more planted and there is no bouncing from front to rear. I'll see how it handles the open road and other bridge crossings tomorrow. Right now, I'm very pleased.
Going over a set of rough railroad tracks I could instantly tell the difference after install.
Only took me about 15 minutes to remove and replace them.
Edited by Vigilante375
On 9/13/2020 at 11:02 PM, 69gto96z said:
Here is mine. 5100s at max setting in the front, with 5100s and stock height in the rear. I plan to add a 1” block to the rear. 295/55r22 Nitto Terra G2s. Slight rubbing at full lock on the liners. Need to do some slight trimming.
I need to find a 1” rear block also but can’t find any? What are you planning to use?
I got a set off of ebay, came with u bolts. Got them installed last night. Should have an updated pic and fender measurements this evening.
3 hours ago, econometrics said:
Probably the best-looking SLT I've seen. Great job on this! ??
Thanks! I really wanted an AT4, but this was on the lot for the right price, right options, and had the 22s on it.
On 9/14/2020 at 5:42 AM, ScX31 said:
Looks great, thanks for sharing!  How is the ride at max height?  What is your fender height now?
Thanks again.
Here is the fender measurements, Bilsteins at max setting, 1.00 ebay rear blocks, and 285/55r22 Terra Grappler G2s.
Driver front - 39.00
Driver rear - 40.50
Pass front - 38.875
Pass rear - 40.50
Stock
Driver front - 36.25
Driver rear - 38.625
Pass front - 36.125
Pass rear - 38.625
Definitely a little more rake than I wanted. I may mill 25% off the height of the blocks to bring it down just a tad in the rear.
Edited by 69gto96z
36 minutes ago, 69gto96z said:
Here is the fender measurements, Bilsteins at max setting, 1.00 ebay rear blocks, and 295/55r22 Terra Grappler G2s.
Driver rear - 40.50
Pass front - 38.875
Pass rear - 40.50
Stock
Pass front - 36.125
Pass rear - 38.625
Your truck looks great!  Thank you for the measurements, looks like it was true to the claimed lift amount. Do you have a side picture to show the rake?  I plan to do the exact same to my Sierra.
Thanks again.
Thanks again.
It’s pretty close. Stock tires were 32.9” and the G2 are 34.3”, so about 5/8” of the lift is from the tires. I would say a solid 2.25” came from the 2.50” setting on the Bilsteins. No side shots currently, but I will try and get one tomorrow.
Shot of the UCA ball joint angle. All seems good. Have just enough gap between the UCA and the tire to slide a finger through. Just need to get it on the alignment rack. I had it aligned when it was on the setting 1 below the top, everything was still in except for the toe at that setting
Finally got around to get my rear bilsteins installed this morning. Driving around town wtf was Chevy thinking using ranchos? I finally understand what everyone had been talking about. Can’t wait to see on the highway. Install was very easy. Thanks to everyone for helping me out.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
