My thought of the flex plate or torque converter being out of balance is out of question i think because if they were out of balance it would do it in park as you rev the engine and mine does not its smooth as glass, but i turned several corners today and powered into hard and it still had the vibration every time. Wonder if it isnt something with the engine mounts being to stiff, but they are supposedly hydraulic so they should take up the engine vibration when loaded. Im lost on it
I am not experiencing vibration when accelerating on either 2014 I have.
The Z71 has a 5.3 and the High Country has the 6.2.
I do not think it is normal.
I have never had a vehicle that vibrated during acceleration that it was normal.
Perhaps it is normal to the dealer because he has a bad batch of trucks that are doing this.
Anybody have the motor shimmed with success. I've seen a couple folks claim it solved their problems on other forums and it was mentioned once early on here, but that's it.
I was told by my dealer that was for a vibration at idle only. But if it has fixed the vibration while driving too I would like to know more about it. It just seems too easy and cheap.
Hey Silver Spaceship, shouldn't you change your forum name to "Silver Shakeship"? :lol:
Just kidding, I hope you get those vibration problems resolved. I have been there with vehicles before and it definitely can be frustrating.
I have a 2014 GMC Sierra 5.3 crew cab All Terrain Package with this same vibration. I have had it at the dealer twice now with the first time the service writer telling me it was the nature of the beast and the second time the right front tire being replaced but no success. I have now asked the dealer to support me as my issue is not with them but with GM and have asked to have a sit down with a zone rep. I love the style and ride of the truck but if I want to drive a vehicle with a vibration I will get on one of my Harleys. I have yet to hear back from the dealer but will call tomorrow, in addition I will be filing a claim with the BBB and blowing up every message board possible stating facts until this issue is either resolved or GM buys my truck back. I prefer keeping my truck but fully willing and able to take the matter to arbitration/litigation if need be. I suggest everyone else having this problem follows suits as there is strength in numbers! Good luck to everyone that is having this same issue and hope resolution turns out well for you.
-JC
Harleys only vibrate at idle - it is the nature of the beast. Once underway they smooth out quite nice.
I'll try that later today. If that is when it is happening to you then I would suspect a bad u-joint or incorrectly installed joint. I say that because when you accelerate hard like that the rear end twists the pinion into a higher angle which could make an existing problem worse.
Will let you know what I find.
So I accelerated at full throttle the other day and found that my truck also vibrates through 1st gear. Actually stops vibrating shortly before the shift to 2nd. Leads me to believe its in the trans.
Mine is just like yours, but it don't have to be full throttle just accelerating hard
Edited by Silverado 6.2
PM26 - My 08 Streetglide at idle yes my 78 Sportster vibrates and my 91 Springer with a 140hp TP motor throbs. Needless to say none are stock since stock bikes suck and all operate/ run and ride as I intended and expect them to. My truck should not do any of those things and is definitely not up to the quality I expect. As an FYI my truck is back in the shop as of yesterday with the dealer now hooking up vibrations sensors to it and oh yeah now that I opened and closed the sliding back window for the first time it sounds like a bag of microwave popcorn as I go down the road. Again the quality I knew and loved with my 08 Silverado Z71 LTZ does not exist in this truck.
I had this happen too. I thought it might be the traction control kicking in until one day the traction control kicked in on some sand and it was totally different. It was after this vibration that I starter to pay attention to the ride and noticed I had a vibration at other times too but not nearly as bad as when I floored it from a rolling start.
Thinking back on when this happened while hard accelerating I would call it a shudder rater then vibration. I know they technically mean the same thinking but if you had this happen to you you know what I'm talking about.
I get the same thing. You feel that shutter under the floor of the truck when you punch it. The vibration/shake happens at higher speeds driving normally, like when you have a wheel/tire out of balance. Of course it must be something else because everyone, including myself, with so many tire changes, balancing, etc. has helped little to not at all.
My money is still on torque converter. Someone on this thread even had theirs replaced then replaced again with a new computer module that tells it how to operate and they say the truck is smooth as class. After they went through the tire and drive shaft circus.
Mine to, I just got a loner and can honestly say there is an issue with my truck.
Sent from my Nexus 5
Could you post that thread if you can find it?
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
