My thought of the flex plate or torque converter being out of balance is out of question i think because if they were out of balance it would do it in park as you rev the engine and mine does not its smooth as glass, but i turned several corners today and powered into hard and it still had the vibration every time. Wonder if it isnt something with the engine mounts being to stiff, but they are supposedly hydraulic so they should take up the engine vibration when loaded. Im lost on it
I am not experiencing vibration when accelerating on either 2014 I have.
The Z71 has a 5.3 and the High Country has the 6.2.
I do not think it is normal.
I have never had a vehicle that vibrated during acceleration that it was normal.
Perhaps it is normal to the dealer because he has a bad batch of trucks that are doing this.
Anybody have the motor shimmed with success. I've seen a couple folks claim it solved their problems on other forums and it was mentioned once early on here, but that's it.
I was told by my dealer that was for a vibration at idle only. But if it has fixed the vibration while driving too I would like to know more about it. It just seems too easy and cheap.
Hey Silver Spaceship, shouldn't you change your forum name to "Silver Shakeship"? :lol:
Just kidding, I hope you get those vibration problems resolved. I have been there with vehicles before and it definitely can be frustrating.
I have a 2014 GMC Sierra 5.3 crew cab All Terrain Package with this same vibration. I have had it at the dealer twice now with the first time the service writer telling me it was the nature of the beast and the second time the right front tire being replaced but no success. I have now asked the dealer to support me as my issue is not with them but with GM and have asked to have a sit down with a zone rep. I love the style and ride of the truck but if I want to drive a vehicle with a vibration I will get on one of my Harleys. I have yet to hear back from the dealer but will call tomorrow, in addition I will be filing a claim with the BBB and blowing up every message board possible stating facts until this issue is either resolved or GM buys my truck back. I prefer keeping my truck but fully willing and able to take the matter to arbitration/litigation if need be. I suggest everyone else having this problem follows suits as there is strength in numbers! Good luck to everyone that is having this same issue and hope resolution turns out well for you.
-JC
Harleys only vibrate at idle - it is the nature of the beast. Once underway they smooth out quite nice.
I'll try that later today. If that is when it is happening to you then I would suspect a bad u-joint or incorrectly installed joint. I say that because when you accelerate hard like that the rear end twists the pinion into a higher angle which could make an existing problem worse.
Will let you know what I find.
So I accelerated at full throttle the other day and found that my truck also vibrates through 1st gear. Actually stops vibrating shortly before the shift to 2nd. Leads me to believe its in the trans.
Mine is just like yours, but it don't have to be full throttle just accelerating hard
Edited by Silverado 6.2
PM26 - My 08 Streetglide at idle yes my 78 Sportster vibrates and my 91 Springer with a 140hp TP motor throbs. Needless to say none are stock since stock bikes suck and all operate/ run and ride as I intended and expect them to. My truck should not do any of those things and is definitely not up to the quality I expect. As an FYI my truck is back in the shop as of yesterday with the dealer now hooking up vibrations sensors to it and oh yeah now that I opened and closed the sliding back window for the first time it sounds like a bag of microwave popcorn as I go down the road. Again the quality I knew and loved with my 08 Silverado Z71 LTZ does not exist in this truck.
I had this happen too. I thought it might be the traction control kicking in until one day the traction control kicked in on some sand and it was totally different. It was after this vibration that I starter to pay attention to the ride and noticed I had a vibration at other times too but not nearly as bad as when I floored it from a rolling start.
Thinking back on when this happened while hard accelerating I would call it a shudder rater then vibration. I know they technically mean the same thinking but if you had this happen to you you know what I'm talking about.
I get the same thing. You feel that shutter under the floor of the truck when you punch it. The vibration/shake happens at higher speeds driving normally, like when you have a wheel/tire out of balance. Of course it must be something else because everyone, including myself, with so many tire changes, balancing, etc. has helped little to not at all.
My money is still on torque converter. Someone on this thread even had theirs replaced then replaced again with a new computer module that tells it how to operate and they say the truck is smooth as class. After they went through the tire and drive shaft circus.
Mine to, I just got a loner and can honestly say there is an issue with my truck.
Sent from my Nexus 5
Could you post that thread if you can find it?
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
