Ok guys I finally found a solution to mine. While using a leaf blower to clean out my garage I thought I would blow under the truck to see if any of the panels were vibrating. To my instant amazement the panels were flopping back and forth or "vibrating". So I cut the most furthest extremes of each side of the plastic skid plate on both the front and bottom sides off (the most flimsy) and took her for a drive. Guys: SMOOTH AS SILK!!! This answers the riddle of why sometimes and not others. Head winds, cross winds, behind other vehicles, etc. would all play a factor in the randomness of this issue. I took it for a 10 mile drive but I've never drove 10 miles before without vibration. I believe I have solved the problem. (At least on mine). So my double cab was probably fine if they would have cut the panels out. Oh well, I now have a 2014 Crew with the All Terrain package and I am just happy I don't have that damn vibration anymore! Hope this helps all of you! Holy sh@t! Where's the Tylenol? :-)
Did you have any noise associated with the vibration?
So I put my truck on the lift at work today and removed the front skid plate, gas tank skid plate, and wraped a budgie around the evap canister and drove it home with high expedtions. No such luck, felt the same as always and possibly worse because I was concentrating on it. It really comes out while accelerating from around 35 to 45 but it always seems to have a slight vibration after that.
I have to say, as someone that was/is considering a new 2014 Silver, this thread is not instilling a lot of confidence in the purchase. Disliked this brand because of my impression of loose steering, prefer the stiffer Ford steering, until my buddy talked me into testing this years rig, much better. Still looser than Ford but perfectly fine.
Now I find this thread and another one, on a different forum, that is double in size. Cut the plastic skid plate seems to be the only solution I have actually seen out of all that I have read. I know some people have different issues or solutions but this one could be a universal solution. Which begs the question as to how this even became an issue, should this not have shown up in the wind tunnel testing? What engineer was sitting behind the wheel doing the observation?
Lastly, someone please confirm how they would suggest go about making sure they would minimize the grief endured regarding this or any other of the issues that are repetitively popping up. I was shocked at the service guy who denied a customer service when figuring the dealer had done all they could do to troubleshoot the problem. I would pulled the guys tonsils out and then screamed for a lemon law. With all the crap GM is going through right now the product quality inspection would be a ton better. We bailed your asses out as a country so you could offer us overly inflated products.
If I move forward with this purchase the dealership better be prepared to offer a very sweet, I mean sweet, deal on an extended warranty.
Silver Spaceship- Sorry to read that didn't fix yours. Mine seems fine now. I would like to go back to my black double cab and take the skid plate off it and see what it feels like. That truck was awful compared to my new crew. Again, both trucks are exactly the same except double to crew and 3:08 to a 3:42 respectively. On my double the dealer replaced wheels, tires, rotors, axles, drive shafts, changed shaft angles and maybe more that I'm forgetting but could not get rid of the vibration which was random to say the least. I know I could always get it to do it with that truck at 70 to 75 with light acceleration or just trying to "maintain" speed. The vibration was significant. You don't have to cut the skid plate off to test. FYI. You can unbolt and test without much work.
Again- This fixed the issue on my truck and it's still very much possible there are other things causing the vibrations. Mine have 1300 miles on it. I drove 40 miles today and could not have been happier. I hope I'm not jinxing myself. Lol. I will continue to report if it comes back or if it remains smooth. (I hope the latter). -All the best to you guys!
Edited by Chappy 1901
I would pass. You could be stuck with a truck you can't drive. The AFM feature is a joke and makes a lot of noise. They have no idea about the vibration. I went through it for three months. In and out of the shop 10 times. Loaners or being stuck at shop. Total not having the truck for about 13 days the first month. I don't care what the extended warranty is. If it vibrates and irritates you it isn't worth it. You can't do lemon law because they will claim that it is within spec and normal. There I said it.
I will not touch anything with an AFM system with a 10 ft pole.
There, I said it.
Thanks for the reply gdadlow and pm26. The price of the rig I was looking at was about 2K below invoice and it meets all of my check boxes but after reading all of this crap it looks like I will have to shell out more money for a ford. Especially when the poll on how you like your truck includes comments to the effect of "I love it but could do without the vibration." Makes me think someone is not being honest with themselves.
Just to play devils advocate for the moment. What is the difference between the AFM and Ecoboost? Don't they do they same thing just in different ways?
Ecoboost has two turbos and is a 6cyl engine. I had an fx4 with one and had lots of problems with moisture in the intercooler. Something the dealer was never able to fix for me
I have seen and had my share of problems with 1/2 ton fords. They all have them. My GMs had all ways got me home, cant say that with the early plug spitting 4.6 or 5.4. I think I would wait to see how those new bodies work out on the new fords. Ecoboost had problems with power loss.
If you go the Ford route, get a 5.0 liter naturally aspirated V8. Ecoboost is just too complicated and too new to be reliable.
Edited by Silverado 6.2
Find one you like and drive it for a day to see if there is anything wrong that you have seen on the forms and if there is tell them you want it fixed before you do paperwork
add a mustang intake and throttle body and wake up that coyote ;)
My company has four 2011 silverados all of them over 100k . And all vibrate and shake . One has we have put 4 tires two different times / shocks and struts / u-jointes balanced drive shaft and now a transmission no fix .Dealership keep saying we don't know . I have read some one else on here say the dealer say farm beaming . As a former mechanic that is the biggest pile of sh&t I have ever heard . That is a full box frame and if that even plausible then you have a defect !!!! I'm looking at the spring bushing and a frame mounts are needing to replaced . Not sure that will be the fix. We have other trucks not GM and had 300k that's had brakes, tires, and didn't vibrate !!!!
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
