I am getting my vibration problem taken care of tomorrow, I am trading my GMC Sierra for a 2014 Ford F150. I will never own another GM product for as long as I live. The only reason I bought this truck is because they lured me in with a voucher for some issues that were out of warranty on my 2007 Silverado. I figured 7 years later I wild get an awesome product, boy was I wrong. The GM engineer hooked up to my truck to the vibration analyzer and said everything is within allowable tolerance and once he said that no dealer will touch my truck with any issue that is related to vibration. GM won't authorize any more repairs for this problem.
GM Customer service wont even call me back. The service manager at Carr GMC told me to trade my truck in for another brand or by a 3/4 ton because of this issue. I am fortunate I have more money then time right now so it's time to cut my losses and move on. I paid $45,000 for my truck and I am getting $38,500 for it now with 10,500 miles on it. It's a very expensive lesson but one I willing to take and never by another GM product. Good luck with your trucks I hope you get them fixed.
Bought a 2014 Sierra back in September. 6.5 box crew cab, Felt the vibration issue on the steering wheel when it hits 80kmh -100kmh. Did the forced tire balancing and did not help. Replace the whole set of wheels and still nothing. Put on brand new blizzaks now that we're in the snow and still no luck. Brought it back to the dealer a few times to replace a whistling sound in the exhaust and repair the vibration issue. Had their tech test drive it as well and he also felt the vibration at the said speed. Apparently they knew of this problem as being in the gear and pinion being off slightly in the rear differential. They apparently replaced it the first time to no avail. So they re-checked it again and apparently the new one was off too. Replaced it a second time and VOILA! Vibration is gone. Apparently GM
Had a problem with the Mould casting they used to manufacture this gear and pinion. But all I know is now the vibration is gone. Nice truck, just too many visits to the shop for me. :-/
I also just called GM customer assistance and told them the situation. I will say that the person i spoke with was every bit as upset about this as i am.
Has any one actually got their problems resolved completely
I am considering filing under BBB, this is the 4th time i will have had my vehicle looked over for this issue.
I strongly recommend contacting the BBB once your vehicle is eligible under your states lemon law. Once you are in the "legal" dialog, verses the customer care dialog, progress is very fast. I received a 100% repurchase agreement. Document every conversation with salesman, service department, and GM; document every repair action; and know the lemon law.
As I am doing research to purchase another vehicle, I see GM is not the only manufacturer with vibration issues.
http://www.tacomahq.com/3392/toyota-tacoma-driveline-vibration-tsb-2005-2014/
http://www.tacomahq.com/3406/2012-2014-toyota-tacoma-shudder/
Edited by goodbye-gm
So GM engineers state vehicle vibration levels are within spec. OK....who's spec are they referencing? They're own GM spec or an SAE spec?
Wondering if they're are independent agencies out there you can hire to perform a vibration analysis. At least this may give you a little more firepower in a court of law to dispute GM's definition of "operating as intended" and "normal and within spec"
I dumped my lemon 2014 Silverado Double Cab All Star Z71 due to vibration and a bunch of other issues, for a Ford F150 XLT 5.0 Crew Cab. After 8 months I'm finally happy again with my truck. I've owned nothing but Chevy for 28 years but that changed in Sept when I dumnped that POS amd went Blue Oval. Never owned a Ford before but I have to say I'm very impressed. Same gas milage, much better ride, and NO vibrations or recalls...or frame rust or weak AC or creaking and popping leaf springs, or recalls, or FM radio not working, or not lighted trim rings for stereo and climate control, or......you get the drift. That 2014 Silverado was a huge mistake, never to be made again. You're gonna love that Ford! I now I sure love mine.
I'm getting the 5.0 also. How do you like the motor power wise compared to your 5.3? I will say the Ford has a few less options that I'm going to miss, like the led interior lighting, but I can change that out easily and inexpensive. I'm glad to hear your happy with the Ford.
Maybe they are referencing a spec they just made up to cover the worst case vibration case so they can get rid of people who complain without doing anything about it.
The only way to determine is this "spec" is meaningful would be to get a copy of it and compare it to max vibration spec numbers from other manufacturers for similar vehicles. And who is going to do that?
Edited by pm26
I think you'll like the 5.0, power wise they seem the same. I'm not sure but it may even be faster than the 5.3. Not sure but doesn't it have 10 more HP than the GM? You're going to enjoy the Ford...its a much more solid, truck feel than the GM...I especially like the exhaust sound. It's just a more solid feel, and the interior is much more comfortable.
If it helps anyone out, my '14 work truck was a 2wd, 5.3L, 3.08, crew cab short bed with trailer hitch. P rated goodyears. Vibrated on hwy. My personal truck (new job so now my personal truck is now my new work truck) is a '14 5.3L, 3.42 gear, 4x4, crew cab short bed with hitch with LT good years. My truck does not vibrate. You would think it should of been the other way around. Not to mention it gets better MPG's vs the 2wd 3.08. Hwy and city. But mainly city it's about 1-2mpg better than the dogged out 3.08.
You took the words out of my mouth, good for you; I'm going in Monday morning to pick up my F150 the sad part is GM just don't care about their customers anymore, they may have won the short battle but not the long haul, I been trying to count how many GM trucks and cars I have owned in the past and the best I can remember somewhere around 17 or 18 and they are willing to let loyal customers go over stepping up and fixing the problems they have with 2014/2015 truck line. So “ALMF” Hello Ford
:banghead:
Edited by DisappointedGMC
comes back to the gm site to talk about his ford..... seriously dude, nice troll.... and all you other folks that don't own the GM anymore. Go to the ford site and be done with it.
Trolls....
Edited by bogeypro
Bogeypro don't be angry that your stuck with your problem riddled GM truck. You could also buy Ford and be happy. I since so much hostility in you, oh its probably because your a Cowboy's fan. He was just giving his honest opinion on how happy he is with is new truck. I'm sure I'll be just as happy now. Go Seahawks, we all can't be winners, we need some loosers to balance out. BOGEYPRO has that covered for us.
Probably lucky you're getting that deal. I was out test driving a ram today and I was talking to my salesman about how I had tested the 2015 f150 and the silverado and he told me that they aren't taking anymore Silverados or sierras as trades because of all the problems. They have a bunch in their used lot and he said they are having a really hard time reselling them. Crazy how word has gotten around on these being lemons.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
