Hello Puckstop,
I am sorry to hear you are experiencing these concerns with your Yukon. Though, it’s good to see you have brought it into a GM dealership to get it serviced. I would be more than happy to offer additional assistance if you need any when working with your dealership. Please private message me with more details if this interests you.
All the best,
Julianne M.
GM Customer Care
Just dropped off my 2015 Yukon for a vibration in the rear. Noticed it the day I drove off the lot. It wasnt entirely consistent but started at 70mph thru about 80mph. I figured it was just a tire balance issue until my service advisor called me today and told me it was a known problem and they would do what they can. I have 2 other issues with it as well; the bottom 3rd of the radio/gps display will flicker from time to time and when I plug a phone into the usb ports, I get a frequency feedback thru the radio. Tried multiple cords and phones with same result. Anyone else have similar issues?
traded in my '14 double cab for a '16 crew cab last week....left the dealership and about 10 minutes later noticed a horrible shake vibration when in Drive stopped at a red light. Truck had 15 miles on it....ugh.
nasty nasty rough idle.
Took it in on yesterday morning, they spent the day doing repair PIP5211D, replacing motor mounts and adding shims. Seemed to do the trick. Drove for about 40 minutes in stop and go traffic. No vibration or shake when idling......until the 45 minute mark. It's back. Not as bad, but still very noticeable. I'll see how the drive home goes, but I have a feeling I'll be bringing it back sometime this week.
THE FRUSTRATION!!!!!
Well, turns out after driving for 10 minutes or so, the rough idle returns. Looks like I'll be taking it back to the dealer again this week. Not looking forward to them telling me this is normal. My '14 did not do this.....
Fully boxed frame
Newly designed cab mounts
New cab design
Just a few big ones
Did the steering system not change as well? I thought it went from a rack and pinion type to what is on it now...could be wrong but it looks different to my inexperienced eyes
The power assist is via an electronically controlled motor, not hydraulic by a belt driven pump.
Ok, so as promised I went to a local tire shop (anyone in the northeast you probably know Sullivan Tire) I didn't have them change any balancing or anything. I just merely wanted confirmation that the tires & rims are true and in good standing.
heres the results :
Tire Location: inner weight reading outer weight reading RFB number
LF needs another 1/4 oz perfect 23 lbs
LR perfect perfect 25 lbs
RF needs another 3/4 oz perfect 25 lbs
RR needs another 1/2 oz perfect 21 lbs
By both GM and Sullivan Tire standards these tires meet spec. although a 25lb rfb number is the upper limit for GM, industry standard is 30lb. Because the truck still vibrates, we now have definitive proof it is not related to the tires, although properly balanced and lower rfb numbers do help to reduce it.
One of the guys I spoke with at Sullivan Tire knows quite a bit about the Vibration issue, saying that they have a few sources within GM itself, and the Engineers there really have no idea why the trucks are doing it, and that they know its a big issue.... just some food for thought.
heres the results :
I could have went to the Adult Mart and spent $30 to have the same tingling in my ass!
In your ass? Wouldn't ya rather go to the Adult Mart and get a tingling on the johnson?
heres the results :
Interesting. My dealership told me tag 15lbs RF was the target for K2xx trucks. They even replaced 6 tires to get them all under that.
This did resolve my 'buffeting', not the vibration which was fixed with a complete rear end exchange. [not in any way related to the last couple of posts referencing rear ends] ;)
My dealer said the same thing, 15lbs.
I've never heard 15 lbs ever, thats half the industry standard
And I've never owned a vehicle that required road force balancing!
  • Like 4
heres the results :
Don't quote me on this, but I think 25lb is the normal GM limit, but one of the TSBs on this vibration issue says that for trucks and SUVs with vibration and/or booming-pressure issues, to apply a lower RF limit 15 lb I believe).
One thing I haven't seen anyone posting is if the results of there RF is 1st order, 2nd order, or 3rd order. I am pretty sure that the Hunter machine will measure all three orders and report if the operator sets the machine to do so. If not, I think the default is to report 1st order only. And, I believe same applies to the balancing: 1st, 2nd and 3rd can be measured, but not by default. So, I wonder if if something is being missed if the shops are only looking at 1st order on the Hunter machine?
Also, don't forget, it is not a Road Force Balance! Balancing is a totally separate step and consider mass unbalance, not Road Force Measurement. High Road Force cannot be corrected with weights. Correction can only be done by indexing the tire differently on the rim,mswitching the tire to a different rim, or replacing the tire. In some case, the RF will be what it is. So, the shop can't always correct it, short of going through a stack of new tires until they find a good one. And that assume the issue isn't the rim itself, which can also generate a high RF (but that easy yo catch by measuring the TIR of the rim without the tire on it. Assuming the shop biters to do so. Another step in the flat rate work they are doing!)
Of course, we all know there does not seem to be any other vehicle that requires such perfectly balanced wheels and tires with such low RF values, so there is no doubt these vehicles are way too sensitive and that is the real problem, not the tires. But, changing tires is all GM can do, since they obviously have not discovered the real "defect", or they have and realize it s not possible, or practical, or economical to correct it.
Well if they really did know the root cause you would think they would have fixed it on new trucks coming off the line. But that doesn't seem to be the case.
And am I the only one who had never heard the term road force balance before 2014 ?
And with that being said, if you buy tires, I would suggest at the dealership.
No tire shop is going to replace a tire that has a RFB of 30. And your local GM service department will tell you that they can't fix the vibration because it is the tires and since you did not buy them there they will have to charge you to get them to 15. If they cant get 15, then you are stuck fighting the tire shop who is going to tell you to fly a kite.
At least if you get them at the dealership, the burden of finding you good tires lies with the dealership. Who must supply to GM specifications...
OMG - I just had a thought, alarming but....
I believe if GM or any manufacturer requires you to purchase a specific product or specification for your vehicle or it will not run properly- they have to supply them. Does anyone know that law?
Here is an interesting read that I found for frame beaming for older chevys, note the lower RFB that GM is specifying.
Boys and girls, the symptoms are very similar to what we are experiencing.
This PI was superseded to add additional info about an oily film on the new mounts. Please discard PIT3009H.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Beam shake vibration is usually felt in the seat and occurring at speeds between 40-50 mph (64 - 80 km/h). Hertz readings using an EVA tool are normally between 8-24 Hz. This condition is most common on extended cab and crew cab models but has also been noted in other models.
Recommendation/Instructions:
The severity of beam shake may vary from vehicle to vehicle. To determine if the concern is beam shake, please perform the following:
  1. Test drive vehicle to confirm the condition. A beam shake condition will usually respond to concrete type pavements more than asphalt, so the vehicle should be driven over both surfaces if possible.
  2. Place 200-500 pounds in the pickup bed between the closed tailgate and the wheel wells. A beaming condition should dissipate.
Note: Tires with excessive Radial Force Variation (RFV) or out-of-roundness can intensify the frame beaming concern. The following radial force variation numbers should be used as a guide:
P-Metric tires (2wd 1500) 12 lbs or less
P-Metric tires (all others) 24 lbs or less
LT-tires 30 lbs or less
If the concern is determined to be beam shake, this is a characteristic of the vehicle. GM Engineering has released updated body mounts to reduce this concern for the Crew and Extended Cab Models. There will be no changes made to the Regular Cab Models.
FOR CREW AND EXTENDED CAB MODELS, REPLACE THE REAR CAB MOUNTS WITH UPDATED PARTS LISTED BELOW. THESE PARTS SHOULD NOT BE USED ON REGULAR CAB MODELS.
New upper and lower mounts should be installed at the left and right rear cab position. The new LOWER mount is a two piece design, meaning there is a rubber mount with a metal washer. Some models may use a one piece lower mount, meaning the rubber mount has a metal washer molded into it. If the vehicle has the one piece lower mount design, washers (PN 15854745, Qty 2) will be needed to be used with the new lower mount.
Note: Some new body mounts may have an oily film covering them. This oily film may be left on the mounts during the assembly process and does not indicate a faulty mount. Do not replace the mount for this issue.
Upper Mount 25791031 Qty 2
Lower Mount 25791032 Qty 2
Washer 15854745 Qty 2 (if needed)
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
