Running LT tires at 40 psi can be dangerous because it is too low of a pressure and heat can build up which in turn could cause a blow out. Most of time when going from a P rated tire to a LT tire about 45 psi is what will carry the same load as a P rated tire at 35 psi. Also the max psi of 80 does not mean much for a half ton truck, the only people who would need to come close to that PSI is a 3/4 or ton truck carrying a heavy load and/or towing a heavy load.
Can you point me to this information on tires please
Go to Toyo's website and download their Tire Inflation Guide. You basically look up what poundage your OEM tires are supposed to handle at the OEM psi, you then divide that by 1.10. Take that number and then find the size LT tire you are running now and find what psi that the carrying weight corresponds to. It is usually around 45 psi. 40 psi is not dangerously low or anything but anytime you run a tire with too low a pressure then excess heat can build up which can cause the tire to come apart, though rare it can happen.
Now I'm confused?
E rated tires are for loads usually an 8ply tire.
P rated tires are exactly that passenger vehicle tire.
LT tire is a light truck usually under 3/4 ton and is suited for light loads 1/2 to 3/4 ton trucks.
Now the psi rating on a tire is what the tire can max handle, this does not mean you should run your truck at those numbers. Your drivers door jamb has recommended tire pressure listed for front and back tires, as well as cold tire ratings.
Running a LT tire, you should be ok from recommended truck's tire pressure up to 45 psi.
Running an E rated tire can handle much more psi as it is usually a 8 ply tire used manly for loads and towing.
The amount of psi pressure you apply to your tires, should always meet the trucks recommended psi from driver's door jamb, and never exceed the max rating from installed tire.
My recommendation are 32-38 psi max for p tires. LT tires 35-48 psi max. E rated tires 35-55 depending on load being moved.
Thxs
After sending a email voicing my concerns this is what I got back, i highly doubt they are going to do anything for me without costing me a arm and a leg. Lemon law for WI is 4 trips to the dealer and im on 2, I highly doubt they will take it back and look at it again. I sent a video of it happening and apparently my console shaking and the stuff on my seats shaking is with-in spec, granted its not nearly as bad as some of the videos ive seen on here, but still annoying
Edited by grizz_wi
Have an independent tire, and front end repair companies review your shake/vibration and let them attempt a repair, then you send a registered letter of defect to GM from your owners manual that you need your truck repaired. Then seek a lemon lawyer, or attorney. Get a video of your truck shaking!
You have this under control, when you are prepared and stay in control!
Now I'm confused?
Thxs
LT is just a light truck designation it doesn't dictate load rating. LT ratings breakdown like so: F rated tires are 12 ply equivalent, E rated tires are 10 ply equivalents, D rated are 8 ply, C are 6. Passenger or P rated tires are 4 ply equivalent. Ply equivalents don't tell you anything about the actual load rating. These are the numbers that follow like 125R or 126Q. The number is it's load rating and the letter is the speed rating you can find the charts on line for each but you would have to contact the manufacture for the correct pressure for your exact tire, the charts on Toyos website are for their tires specifically but pretty close in general probably within 1-3 PSI.
I have a question and anyone can feel free to chime in on this.
Out of the 727 pages of information generated by pissed off GM customers, how many accumulated problems
With these trucks have we compiled?
1. Vibrations
2. Frame beaming/ cab mount issues
3. Preload incorrect on pinion
4. Tires,rims,tires and tires
5. Front wheel bearings
6. Ring and pinion/ carrier assembly
7. Driveshaft
8. AFM
9. Aftermarket exhaust
10.
1. Vibrations
7. Driveshaft
8. AFM
10.
My buddy's friend was over, we were shooting the shit about cars and stuff he entions he works for a dealer as a servicemanager.
Well I almost fell over my self, boy did I have questions for him.
I asked him about the vibration issue happening on these trucks, well he told me there's an issue without a doubt.
He says they all have the clunky transmission, and weird shifting issues, but the vibration issue is real.
He says out of every 10 trucks sold, he is dealing with 3 trucks with vibration, shaking issues.
Some are worst then others, and he metioned about new bushings coming out, as well as new body mounts too.
He also says the exhaust flapper was an issue for some trucks, but this is only part of the issue.
In most cases, he has asked GM for assistance to get them into a different truck, as he had no solution to correct the vibration issues for most after many attempts.
UPDATE: Just got a call back from my CEM (Customer Experience Manager) They swapped out tires and wheels with another truck and the vibration was still present. He said they have direct contact with a "subject matter expert" who had them swap the left front hub, vibration still present. Next it looks like they will run the truck on a lift in 2WD and 4WD to find out where it is. I am just happy that after over 20 days out of service GM is finally accepting that it is NOT a tire issue. The word that the PicoScope gave them today is excessive lateral runout. Which to me would be a tire issue. Not sure what components can be effected by lateral runout aside from Tires and Brakes.
Im now in a Yukon rental and guess what.....It Does NOT Vibrate!
Interesting, I believe you may be the first that said the pico scope is saying lateral run out issues. Let us know what they find if anything.
My dealer had the truck for another day today, said they were going to do all sorts of tests. Got it back, was told "performing as designed"..the SOBs even scratched my rims again too! I sorta knew that they would say this after "consulting" with GM.
Wrote GM today, guess I will start the bullshit with GM now.
The service writer did not even write the complaint down right.
I had to complain to them about documenting the issue correctly all 3 times i went in. Made them rewrite the invoice. They were not very happy with that. After that they threw my aftermarket parts up in my face, told me that i voided my warranty and any repairs that they would do iwould have to pay out of pocket for. Following that conversation i called the 1-800 GM cystomer service number to complain about how i was treated. The following day after they contacted the dealership they returned my call stating word for word what the dealer told me about voiding ny warranty. Complete bullshit and i am done with them, decided to try and figure it out myself.
I have 18s. The part that has me confused is it doesn't always do it.
I have a 15 Z71 that came stock with 18's and good years, it also vibrated intermittently over about 68 mph. I put 20's on it with BFG All terrain t/a ko2's and it shook the teeth out of my head, but not all the time. Had them damn things balanced 3 times, It got a little better but was still there. It really seemed magnified with the 20's on it. After fighting with the dealer who refused to service the truck because I had aftermarket tires and exhaust on it. I put the 18's back on in no particular order and the vibration was almost nonexistent, until they did the service and rotated the tires. Out of both sets of tires I had each balanced 3 times by either the dealer or the local tire shop. As of right now the vibration is minimal but is still there, talk about wasting 2k on wheels and tires, that you cant use, on an off road edition pick up truck that comes from the factory with radial tires....WTF :wtf:
So what happens when you have to get new tires??? Go through the whole horseshit circus again?? :banghead:
Just an update
got another opinion or rotate and balance attempt at a independent tire store.
And after 30min. and 50$ my truck rides better than it has in a while.
so it seems you can get different results from different techs and tire machines.
still got the low speed vibes from bumps etc, but anything over 45 is smooth as it was when new.
A sense of relief for sure. I'm feeling so much better about this truck.
o, btw im still riding on the stock SR-A's
Edited by Gofas
More than a few have noticed reduced vibration for a week or so after being up on a lift to have the tires rotated and or balanced. Hopefully yours stays that way.
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
