So I get a text from the dealer late yesterday saying the truck is repaired and is smooth on the highway. I said "So the Michelins did the trick"? He said YES. I said great, I'll see you tomorrow afternoon when I get off work.
But going back in time and knowing the amount of tires they put on the truck including the original set, the set of tires and OEM rims I bought, a set from a brand new truck on the dealers lot, and a brand new set of Bridgestone's that were perfectly balanced to 7 LBS each per the SM it makes me wonder if in fact it was the recently installed and balanced driveshaft that was the fix and the tires are a cover up? As much as I appreciate the Michelins, (Great tires) when he told me the driveshaft was "slightly out of balance" and that they swapped tires from another new truck and it repaired it, I stared to wonder because the timing is what is questionable.
Wondering now when I pick it up what the paperwork will actually show completed after a month and 1/2 in the shop.
One things for sure, Chevy needs to change their motto from "LIKE A ROCK" to "MORE SENSITIVE THAN A WOMAN".
“Hallelujah! Holy sh*t! Where's the Tylenol?” (Chevy Chase)
GMCJOE17: please report back about your personal "feelings" about the vibrations, I hear too many times GM says they are fixed until the owner test drives and feels anything different.
On 11/1/2018 at 12:41 PM, GMCJOE17 said:
Got a call from the Service manager at the dealer. He said they got the driveshaft back and he said the driveshaft company said it was slightly out of balance. They put the driveshaft back on and it still vibrates. He said he took another set of tires off another truck and put them on mine (AGAIN) and the vibration went away.
He told me he is going to order a brand new set of Michelin tires for it, the best tires for this truck under warranty and he said of that does not correct it then its the rims. I said you would figure the rims would have shown any imbalance on the balancer. He said the machine will not show where the tires bolt to the truck. I said I find it strange that the original rims did it, the set I bought did it, the set you already swapped from a NEW truck did it, and now you changed them with another truck and it went away?
Sitting here SMH and fed up with the entire thing.
Get Michelin Defenders....
So I got to the dealer after work today and the SM told me to go ahead and take it on the highway and come back to make sure I was satisfied. Jumped in and all seems good @ 70 only truck normal bounce.. @ 75 same and @ 80 mph all good. Got back to the dealer and did a once around and did notice a door ding right in the middle of my drivers door. He got me some touch up so I will have to do a little sanding in the spot first. Other than that, one of my nice tire caps was missing but he threw a new one on and even had a porter fill the tank up for me which was nice. (but they did rip through what I had in it)
I am happy it rides like a normal truck but am a tad worried that this issue could return as the tires wear or the truck gets more miles on it. Time will tell on both. I am thinking of throwing some Bilstein's on the back to control the 8 ft bed a little better on the highway. The dealer did give me some sand bags (same bags GM made them buy in troubleshooting the truck). He didn't have the paperwork ready but he said he will email it to me when its done. I imagine 5+ weeks of this thing clocked up some hefty GM billable hours. He did tell me that GM wouldn't approve the Michelin's so the dealer ate them. (Which means they ripped them off another truck on the lot and threw the Bridgestone's on it)
My poor rims have been through road force balance hell with the multiple sets of tires on and off of them in the last few weeks.
More to come when I get the paperwork, glad to have the truck back after this long too.
Joe
On 11/3/2018 at 1:14 PM, GMCJOE17 said:
That's what they put on!
My 2015  2500HD. 4x4 with 8 ft. bed came with Michilen tires and has been smooth as glass since
new.
47 minutes ago, GMCJOE17 said:
I drove it 150 miles last night and it was smooth the entire time!
So what do you think it was? Driveshaft or tires?
Also, what specifically did they do to your driveshaft? Balance? New from factory?
I know, I am about to schedule another appointment and don't know if I should let them decide on the plan of action or try and persuade them down a specific route first versus another. Now the more I have read all the issues with shake/vibration it might be a multiple factor which some people may have some more factors than others. Should the plan of attack start with tires or other parts (driveshaft/axle) route.
Bill,
I think it was a mix of the Driveshaft balancing (it was reported as out of balance but I never got to see the data on how much) and the better class of tires. Its like night and day on the highway now.. smooth as silk!
Joe
10 minutes ago, GMCJOE17 said:
Bill,
Joe
That's great! All the way up past 80mph? Also, how much does a dealership charge for a driveshaft rebalance? Or was it covered under warranty?
Edited by Bill Reinhardt
Dearmosd,
The dealers are at the mercy of GM for all warranty work. It has to be approved for them to get paid for warranty labor and parts. Luckily I had a really good service manager who made the world of difference in my case and I also shared the information with him on what I read on line on this site and others. If I were you I would start with the service manager, if you feel you are getting a run around then turn up some heat by placing a complaint with the BBB (https://www.bbb.org/). They will then contact GM who will assign your truck a case number and contact the dealer directly. When doing so, you will need to upfront state your case on what you are looking for whether it be a lemon law case or reimbursement for any out of pocket costs you spent on getting the problem corrected. The dealer will then have 14 days to correct the problem or report to GM that they can not repair it and then the lemon law will come into play. In my case I bought my truck used so I didn't qualify for the lemon law but I pushed for arbitration and they settled before it went.
Good luck and I'll follow your posts for sure!
Joe
All warranty Bill, and yes I took it to 90 and it was perfect. The crappy thing about GM is they covered the Bridgestones under warranty but refused the Michelin's. The dealer told me they ate the tires on this one (which they got the set of Bridgestones so they came out ok).
    • As the title suggests, I have an unused General Motors authorization code for a set of bed perimeter lighting lamps that I bought. My truck was built with the option for perimeter lighting, and they worked without programming… So now I just have this code. What is it good for now? Can anyone here use it?
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
