Took mine in today and they ordered a seat track. The mechanic said he's replaced one on another '14. When I asked about the TSB that has been mentioned he said he didn't look into that because he already knows what problem is. Oh boy, wish me luck. Part should arrive at dealership in a few days.
That's a lot better than ordering a bunch of clips or hog rings.
Just got my truck back today from having PI-1138 done on both seats. It took them an entire day to do and I have to be honest after picking the bloody truck up and spending an hour in it I can honestly say the problem is now WORSE!! more movement and play all around.. Will likely wait until a real fix is discovered befoe I waste any more time....
Thank you,
Alan
Took my truck in for it's first oil change and mentioned the loose seat to them. They ordered a drivers side seat track and said they would call me when it comes in. He said they were re-doing them and are on back order. Pt number 13582540
I believe that's the part number they installed on mine and it seems to have worked. Seat is pretty solid. I'll double check and post the work order.
Edited by TX14Z71
This seat does not vibrate or move:
Of course it doesn't! But you are stuck with what might be considered one of the ugliest trucks every produced! :pimp: However, the great side sticker certainly helps its curb appeal.
Took mine in today for the recall check on the tranny lines. I'm friends with the mechanic, I mentioned the seat. He ordered a new seat frame and some additional bar for more support. He said he added the bar to a few new ones on the lot. Said the key is to install the support bar on a "new" frame. Who knows if it will work, we'll see I guess.
I purchased a '14 Sierra SLE 2WD Crew Texas Edition about a month and a half ago. Mine is a early build...build date is 5/13. Now I thought long and hard about buying one of the first to roll of the line but I liked the added equipment I got before the Mid year price increase( old invoice). Well now I regret not just getting a newer built truck. I have 800 miles and the seat click is driving me bat a$$ crazy! I'm very,very OCD about things and my dealer just thinks I'm crazy. I'm actually a QC Mgr. I complained about the vibration at hwy speeds...nothing. I complained about the shudder at stop lights....nothing. I complained about the seat click....nothing. Ok so I finally get angry enough to get a lawyer involved and I get their attention. I think this forum helped more than anything. When I showed them that there are problems from a lot of others they finally got their lazy fingers to typing and found out that I'm not a loon. They replaced three of the four GY tires and shimmed the motor mount 3mm....problems solved. Now I'm going back in about the seat issue...they are going to chit bricks. I'm going to demand a new track,frame and support bar...wish me luck guys.
Part numbers?
I like this guy!!!
can you tell me more about this recall?
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
