the dealer fix does not work. i wish someone could just sticky the fix somewhere.
read the thread. $5 fix. Do it your self. [emoji106]
Sent from my iPhone
using Tapatalk
Hi, I have just over 4k miles on my 2014 All Terrain, and the seat movement issue just started, pretty annoying!
I'm trying to read through the 527 posts, across 36 pages, but don't see the DYI fix. Could someone provide me a hint as to which post # has the fix?
Look on pages 27 and 29 of this thread.
The 1" pipe clamp is in plumbing.
The 3/4" rubber C clamp I found in a plastic drawer of specialty hardware.
The fix works!
Sure would be nice if they could make them fix the a posts so it showed up at the top of every page in the thread.
it would be even nicer if GM fixed or redesigned these seats.
I bet that even a new model A Ford you could buy new for $ 385 eighty years ago did not need hose clamps to keep the seat from moving around. How has technology progressed! Now GM trucks costing more than 100 times as much need them.
Edited by pm26
Clamp it baby. Save the headaches!
Agreed, but no one in this community can do that and this idea could help on other threads that have nothing to do with a GM problem.
Interesting...Ford to the best of my knowledge still isn't using hose clamps on their seats.
By the way, I had my dealer fix my seat last summer. They ordered the parts and then farmed the work out to an Upholster who removed the seat cover to perform the repair. The problem has not returned and its been over 7 months.
I need to call my dealer since they were waiting on parts. I'll use the hose clamps but I'm going to make them work still.
I have this PM with GM:
Sent 21 January 2015 - 02:46 PM
Hi,
Is there a real fix for this? The message posts shows people saying that the dealer fix does not work and that we should buy some clamps. I have just over 4k miles on my 2014 and it does not make sense for me to do this.
Sent Today, 12:04 PM
Hi boston850,
Thank you for reaching out to us. I understand you're concerned about the seat movement in your truck. Please know that we've done extensive research and have given all pertinent information to the dealership. Since I'm not trained as a technician, I'm unable to provide any technical information. However, I do stand by the dealer’s expert opinion as they're our eyes and ears within the field. As a result, I recommend going in for a diagnosis and giving them an opportunity to address this for you. I'd be more than happy to reach out on your behalf and ensure all of the available resources are utilized. In order to do so, I'd need your contact information, VIN, and the preferred dealership. Please let me know if this is something you're interested in.
Sincerely,
Sent Today, 12:18 PM
Hi XXXX,
I have already spoken to my dealership, and they were not aware of this issue. So, I don't want to start from the beginning with them. Also, others in this discussion were not able to get this fixed at the dealership.
So, back to my original question. Has GM looked at the fix applied by users in the thread?
Sent Today, 04:01 PM
GM Customer Service, on 23 Jan 2015 - 3:11 PM, said:
Boston850,
As mentioned, I'm not trained as a technician so I'm unable to verify whether the fix applied by other members on the forum is able to resolve this concern. Again, I'd be more than happy to contact any preferred dealership and discuss things further with them. I can also contact our internal resources for additional support if necessary. However, in order to fully assist, I'd need the requested information and a diagnosis has to be performed by the dealership. Please let me know if you'd like to proceed.
Sincerely,
Eddie A.
GM Customer Care
You are not answering my question! I don't need help going to the dealership. Is GM aware of this FIX? period.
Edited by boston850
Yes, they certainly did an extensive research how to make the cheapest possible seat frame and charge the highest possible price for the truck. :rolleyes:
Yep...that's actually exactly what they did and do. A relative of mine is a designer at the Warren tech center...this is how they roll. They come up with a design that works then cheapen it up as much as possible.
profit baby profit
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
