How much is the BB tune vs. Diablo tune? I went on BB.com and it was for $900?? Seems very high for a computer tune. Is it something thats plug and play? Or does it take a long time to set up the tune myself?
Its about $600 for the Autocal. You can for the most part do it yourself to get files and logs. They do the actual tuning through email. Worth the $600 and time.
Chris is correct, $599 for the AutoCal. You must have been looking at the V2 which is $899.
Sent from my fone.
I did the BB EFILive Autocal for $600: http://store.blackbearperformance.com/EFILive-AutoCal-Tuning-System_p_8.html
Worth every penny.
Here is the process:
1) Order and receive the Autocal tool. 2-3 days shipping
2) Install software onto your computer that connects to the Autocal device
3) Plug device into your truck. Activate recording. Drive for 30 minutes to record your trucks shifting and details.
4) Use device to record engine and tranny config files (detailed instructions on site)
5) Email files to Blackbear along with requests (disable AFM, faster shift points, etc)
6) 2-4 business days later you will receive new tune files. Copy files to your device, plug device back into truck, and reflash the engine and tranny config (very easy)
From ordering to having your first drive with a new tune took me about 2 weeks. For $600, the change in how the tranny and engine perform in phenomenal.
Edited by Haus_Z71
Purchased a Diablo, be here in a few days. Hopefully do the trick for this rooky. Couldn't see spending the $600 beans, maybe down the road turn to BB.
I had the DiabloSport tune on my 2005 and now on my 2014 for a year now. Pretty happy with it. Not knocking BB because I've heard nothing but good about them but since you now own the DiabloSport tuner you can always save some money and get a custom DiabLew tune from Lew later on.
Got mine tuned today :)
Truck specs and tune please :-)
Oh sorry didn't see it in the lower corner of the image.
Edited by mjj
No worries man. It's a 2015 Sierra 1500 SLT 6.2 with Max trailering (3.42)
I'm unsure of the tuning program they used. They did my last truck and I was wicked impressed.
Josh
I tuned mine last night with the Diablo Intune and it makes a heck of a difference!!!!!!
I don't have mine yet, but did you select a specific tune for yours?
I used the Diablo flex tune and I currently have a tank of 93 in it can't wait to put some e85 in her
I also use the Diablo 91/flex tune. I keep AFM on, drove with it off for a month this summer and lost 1mpg. I have the throttle boost setting (I think that's what it's called) set at +6. For the transmission tune (TCM) I use the hard shift setting and I have torque management turned off. I've also been using E85 almost exclusively since I've bought the truck. Almost 20k miles on it and for a canned tune I've been happy with it, truck shifts better, more seat of the pants as they say feeling during acceleration, no complaints.
Is the Torque Management just on/off or do you get a slider? Sadly EFI Live they can't adjust it just turn it on or off. I'm curious if they are just doing the same thing EFI Live does by not letting the timing retard as much on shift. If that is the case, its pretty bad on the Tranny. I've been debating at some point possibly getting HP Tuners since you can actually adjust Tq Management.
I am also curious of this setting?
Read this whole thread, and I guess the consensus about the warranty deal is don't sweat it and just tune it. I've made my mind up to go with Black Bear's Autocal.
I was wondering if weather conditions, mainly temperature can make a difference when you do the data logging. Is there an optimum temperature range for doing this, or doesn't it matter.
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
