Just to throw this out there. I am not one of these you will void your warranty guys, I have tuned everything I have owned and have a tune written waiting to install on this one when the time comes. I was talking to the service guy at the dealership yesterday about my gear install, not even discussing re-calibration or tuning, and he told me whatever I do do not put a tuner on this truck to correct for the gears. He said he has a 14 6.2 in the shop right now that had an engine knock. GM made him pull the cal file and send in for evaluation. The truck was tuned and he had to cancel the guys warranty. Stuck with a 55K truck with a busted engine and a 13K bill if he wants them to repair it. The guy initially denied it but he eventually admitted that he had tuned it. This is just hearsay so take it for what it is. I still plan on tuning mine but it will be a little later down the road once more reports come in on how they hold up. He informed me that DSI, the company that does their lift installs, can re-calibrate it and it will still be covered under GM warranty.
^^^^This post could have been posted by me^^^^, I would love to tune all your guys trucks because it is something I like to do, I just like to make sure that everyone is aware of the consequence's before I do tune. I have a full time job and don't need your tune to pay my light bill this month, or I would say "GM will never know" like most other tuners out there. As soon as I'm comfortable with my truck and feel its time, I will tune mine. I have only had my truck 6 weeks and have 9k miles on it so its not like my warranty is going to last long anyway.
On another note.... You will love your truck all over again if you get a good tune from a reputable tuner. I advise putting all your mods on first and just getting a full dyno tune. You will not be disappointed and if he is a good tuner, it will only increase the life of your drive train unless of course the new power can't keep you off the skinny pedal.
Steve
There has to be at least a 1000 web pages of people talking about how these chips are a farce. I would suggest returning that "chip" back to where you got it from unless you are wanting to possibly damage your engine.
As said they tell the ECM that the incoming temp is 20ish degree to try and get the ECM into the richer part of the stock calibration. This is exactly the wrong way to do it, if you want to pick up power get a real tune otherwise just drive your truck.
since i no absolutely nothing about them
is it possible to tune a 5.3 to make more of the torque in the lower rev range for towing etc.
mike
Yes, that's the nice thing about VVT. You won't get 6.2 torque but it will get better
Custom Dyno tune... From a reputable tuner
Sorry, not familiar with any tuners that far North. I would reach out to local area car forums or friends and see who they recommend in your area. If you don't find a dyno shop to give you a good torque tune then you are at the mercy of mail order. Although I have used neither BlackBear or Diablew (diablo custom tuner) I have heard a lot of good things about both of them. They may be able to give you what you want remotely, it would be worth the call to both just to see what they offer.
Custom tune is the way to go. EFI live or HP tuners
Your constant harassment has caused me to break down and tune mine. If I get a little free time this weekend, I will have something to report back with next week. I actually already have a base tune built with DOD modifications, shift improvements, torque management reduced about 50% and WOT tables cleaned up a bit, but I will need to dial in my VE for all cam positions and recalibrate the MAF before messing with the timing. After all that is done... I'm fairly confident this little 5.3 will be a beast in comparison to the stock calibrations.
Now I just need to get to the exhaust shop and get an O2bung welded in for my Wideband.
  • Like 3
Lmao. Glad your doing the tune. DI 5.3 respond well with tunes. Glad you came to the light. What wideband you going with?
I have a little F.A.S.T. Dual Wideband kit that I use when Dyno tuning. I'll put it in and make it semi-permanent for a couple weeks while I dial in the VE, Maf and PE tables.
Edited by iCryWheniGoPoop
It's done, no sitting on the fence about tuning, I couldn't take it anymore.
By simply lowering TQ management 50%, shorten shift times by 20%, raising shift pressures 10%, cleaning up PE tables (WOT) to give a target AFR of 12.7, bumped timing up 3* on gas and 5* on alcohol in WOT it's a new truck.
Truck has 5.3 with 3.08 and will bark second, if for some reason it didn't spin through first and second. From a 15MPH roll I can shred the tires. To be fair it is winter and the roads aren't the cleanest but it's still night and day from stock.
I will be dialing it in for a couple weeks in stock trim to see what kind of gains I can make. When I'm happy with my tune I will take it to the Dyno and post "stock vs street tune vs Dyno tune" numbers just like I do all my projects.
  • Like 3
Congrats! It is going to be really hard not to install my tune once the gears are done. Might as well just say the hell with it and join the club. Curious to see the results once you get it dialed in. Looking forward to more feedback.
I will keep you guys posted, and welcome any local guys to the dyno when I go, that will give me a couple extra gear heads to mash the skinny pedal for me while I watch what's going on.
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
