Yes.
Duh, you clearly said you used an LC1...
I'm guessing you Dyno'd it, what AFR did it like?
Edited by iCryWheniGoPoop
I can't imagine it NOT being able to change your speedo calibration. As far as fuel mileage, that is dependent on the current efficiency of the vehicle. A good tune will never make it worse. The truck will feel lighter and MPG gains will be minimal, maybe 1 sometimes 2 mpg on the average vehicle. Thats a good tune in general, I never run canned tunes and I'm not personally familiar with Diablo/Diablew except for the mostly good things that has been reported.
If you were closer I would help you out, I don't do this for monetary gains, its just a hobby.
I will have experience with Lew's tune soon. I'll be sure to report out once it's dialed in.
I don't remember actually.
It was close to 14.0 AFR. I don't have a permanent install but I will. Just working to much.
ThAts really lean for WOT, it should be around 12.8-13.0ish
Oh I know didn't get to spend much time for the tune. Once I get more time off and can use the dyno again and get a good tune dial in. Let you know where it works best for my motor. My buddy had limited time for the dyno. So kinda cram it in. I didn't put much timing on it either. Only 3°. I still have a lot to work with to get it right. Once I do I get the dyno results posted. Its on me right now since I'm working a lot. You will probably get yours done before me.
Put the wideband in permanently now. Got it down 13.2. Just finished it. No dyno though. Just driving it on the street. Adjusted timing again. Running good now. Still needs more tweaking. My buddy help me the first time and I didn't see the AFR until I texted him. Oh well.
Bullydog GasTuner shows support for our 2014
5.3, with claims of high HP and high TQ boosts with also MPG management if that's what you're going for... Opinions?
Mine cuts off at 98, I would love to take my off
98 is not fast enough though, lol
ontario canada
I live in Canada too.. Justin at Blackbear has done my last two trucks, and will be doing this one.
I'm looking to tune my 14 to primarliy reduce the torque manangment which is driving me nuts. At $307 through Amazon (http://www.amazon.com/DiabloSport-I1000-inTune-Vehicle-Programmer/dp/B0064IU5FW) this might be the most economical method.
Just a heads up for everyone... if you purchase the intune for any less than $389, Diablo will not warranty it. I talked to Chris at Diablo and the companies that are selling them cheaper are not being sold to anymore because they are not following diablo's selling guidelines. He said if something happened to it, they will ask for your receipt to verify you paid the correct amount, and if you didn't... you are SOL.
http://www.diablosport.com/company/unauthorized-dealers.html
LOL... That is about as big of bullshit as I have heard in a long time. So.... what I get from this is if you are not aware of their dealer pricing practices and search for the best deal out there (which 99% of people do) then you "could" be hung out to dry because you (the end user) tried to save a couple dollars. The issue that Diablo is having with their dealers should not be taken out on the end user, even if it is just an empty threat. The fact that Diablo even posted that on their Website is somewhat disturbing to me.
After stewing on this for a few minutes, I think this warrants its own thread.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
