I expected a larger bump
Sent from my SM-N900V using Tapatalk
Most ppl post up dynajet results and there more forgiving here's the other one-
Baseline with Corsa. It added 8 hp bone stock run was 285 I don't have that sheet sorry
Edited by Dj0nes
Mine was on a Dynocom.
Yeah I'm sure they're all a lil different. Numbers are numbers in my opinion. The over all drivability is completely different. I also didn't have them tune it all out and advance timing to much. Only advanced it 3 degrees. I'm sure more could have been gained but I'm staying safe. The shift point and tq lock up changes improved everything. This is only the first round I'll be taking it back for tweaks eventually once I get a feel for what can improve still.
I was expecting more because the stock numbers for the new 5.3 and my LQ9 are near identical. Mine put 325 To the wheels. The tune was awful as well and I had it redone for divability
I didn't make near 325 to the wheels stock. I haven't seen any make near that lol. Must have gotten a good motor or the dyno was a lil overzealous with the results. Most Ive see are around 290-295 to the wheels. STPT numbers are true to the wheel numbers.
I didnt do that to the wheels stock. It was the 6.0 with a 5.3 K&N intake and 5.3 MBRP exhaust then a tune. This thing is 345 at the crank stock
Ohhh I understand now. My bad.
Why don't they show anything below 2500 rpm? I want to see what they look like in the "normal" driving region.
That's how all dynos work. 3rd gear pulls from 15-20 mph. In the "power band". You wouldn't see much of a difference down low on paper but real time driving it's day and night. The truck holds gears much better and never downshifts when going up hills. I put it to some tests yesterday and was very impressed with the gains and trans shift points.
On paper all of the gains were at the top of the rev range which isn't that encouraging. The consolation is that you did feel the difference in normal driving situations where it matters and.
Personally I would love to see low and mid range torque and power improve along with the gear change alterations.
Im a big fan of the BB tune and a buddy of mine just got his new 14 done and loves it
Did your buddy get his 14 tuned with the ecm or both ecm and tcm?? Ive been waitin for the tcm to come out
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
