Good to know. First time I tried to stop this truck, I though man these brakes suck! Coming from a Toyota Tundra that had massive brakes, the ones on this truck are terrible. First hard stop I had to make I thought I was going to hit the car in front of me. Keep in mind, I'd also just traded in my 2012 CTS-V on the GMC and that car had massive brakes as well.
  • Replies 30
are these rotors pads recommended if you are towing a lot?
I havn't had a chance to tow on the new setup yet but I would say why not? The new pads being Ferro-Carbon dissipate heat better, bite harder, and are more resistant to brake-fade. The downside being that they will ultimately cause more brake dust and last less than the OE ceramic pads. In my opinion if these last 50k miles I'm gonna be more than happy, they are cheap enough and easy enough to change out and the increase in performance is worth it.
Braking performance is a balancing act. Stopping feel power vs noise vs dust (which can ruin a wheel if not cared for)
I was interested in your feedback because I was afraid you would report back with a little noise which all my cars had on HPS but their purpose was different.
For the truck I'm completely happy with my factory stopping power, and there is plenty of lane left at the end of Tulsa Drag Strip for 6000 lbs at 110 mph (one day) when I finally make it out there so I'm already over the HPS upgrade for me.
Thanks for posting this good info and the rotors are sexy.
Sent from Off Driller Side
The one thing I'll ask you update us on is the amount of brake dust this new setup accumulates.
I notice that the OEM pads and rotors do NOT accumulate very much brake dust at all. Every time I go to wash the wheels they are only dirty from road grime and what not. Never brake dust.
Compared to my Dad's 2014 Ram. the inside of the barrel and the spokes of his wheels are always covered in brake dust.
Ive ran these on two camaros and the brake dust will be more than OE as well as noise from them. However, if given the choice Id never even think about going back to OE. The stoping power greatly outweighs the extra cleaning and noise. For the price of doing this it is well worth the money. You could spend thousands to get the best but were talking a few hundred and a 6 pack. I changed all mine out with never doing a brake job before in a few hours. Just get on YouTube and find a Good DIY video
Just wanted to give another quick update;
The break noise has increased and now does it 80% of the time when coming to a full stop once I'm anywhere under 20mph. Its gotten pretty bad, to the point that I now have to address this issue. I'm almost certain most of the noise is coming from the rear OE rotors that I did not change out. So now I can do two things. Spends $150 on the same Hawk Quiet Slot rotors for the rear and HOPE the noise goes away, or replace the rear pads with the OE pads. I would lose a bit of braking power but not nearly as much since the front brake system does most of the stopping power.
Decisions decisions....
Another note; the new cabins insulate noise so f'ing well. I was only hearing a slight squeal until I began driving with the windows down now that weather has cooled a bit and oh man. The squeal coming from the brakes is piercing to say the least.
haha, unlucky lately!
Jesus christ tell me about it.
At least the truck looks good and standing still everything works perfectly!!!
Thanks for the updates. After towing my TT this summer I realize I need a brake upgrade.
Sent from my Nexus 6 using Tapatalk
I'll bet you are right if you put Hawks on a glazed rotor? You may still be able to run them to a shop and have them turn the glaze off then re burnish those rear pads in again. It's worth a shot anyway.
We're u able to help the noise? Just curious if you tried turning the glaze off the rear rotors.
  • 1 month later...
+1
I personally think the 2014+ trucks have amazing stopping power in stock form but I also came from a 2002 ext cab silverado that had probably the worst braking system in the world.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
