My b pillar has been quiet.  I’m keeping my fingers crossed  that it isn’t coming back.
However, Anyone on here have the passenger seat rattle on bumps?  It comes and goes.  It seems to happen after someone sits in the seat (and now it seems to be happening while someone is in the seat).  I actually think the seat frame is broken in the back.  I can push on the back of the seat and hear the metal squeaking around back there.  I’ve stuck a towel in the seat back pocket and that has seemed to buffer the sound.
I was thinking about taking the seat covering off (leather bucket no power) to see what’s going on.  I’m not really sure if i want to mess with it
any thoughts?
(incidentally i took the truck to the dealer this morning to have them plug a tire that i had a nail in and of course the seat wasn’t making any noise at all... go figure.  So they couldn’t do anything)
On 5/12/2019 at 6:34 PM, mojohn said:
I am cautiously optimistic that I've found the cure for my passenger side B Pillar ticking. Went through almost every suggestion in this forum. Finally, I removed the lower pillar plastic cover and saw that a couple wires connected to the seat belt mechanism were very close to the cover itself. The wires are at / near floor-level. They were like almost rubbing the cover. See image. I then wire-tied the wires to the metal B Pillar.
I noticed in the middle of the B Pillar is a wire bundle. Just for giggles, I wire-tied that wire bundle to the B Pillar, too.
Been a dozen or so trips since, and the dreaded B Pillar tick has been fixed. So far.
Best,
John,  KF5ZMD
Well, she-ott.
Fix didn't take.
Back to the drawing board!
1 minute ago, Bob Miller said:
That sucks. Out of curiosity what’s the temperature outside where you are?
84 ° this afternoon.
It seems to do better when it's cold.
Best,
John, KF5ZMD
Okay that’s what I noticed too when mine was doing it. When it cooled off in the fall it stopped. Then  it came back for a day or so back in January sort of randomly.
Try this because mine seemed to stop for good (fingers crossed)  after I did this.  Open the back door and take the rubber boot / connector that attaches the wiring that comes through to the door to the plug in the B pillar off and then reconnect it. It’s a connector where you pinch on it and it should snap out. Mine had a bunch of play. I could really move that rubber boot around the hole. I’m curious if that stops it for anybody else.
Some metal inside or under the b pillar is expanding and tapping.  I think it is a combo of heat and humidity because we have had days here in SC where the temp is well into the 90s and I don't hear it, yet 70-80 degrees on a damp morning and the sob is rattling like there's no tomorrow.
Thanks, I'll give 'er a whirl.
John
I did notice last year it was much worse in the mornings during the summer here in Houston.  Damp humid mornings.   Thing would rattle on every bump and groove in the road.
But on the drive home from work after the truck sat in the parking lot all day in the heat and sun  it would either not do it or it would be real faint.
We’re starting to get more damp and higher (mid 70s) temps in the mornings now and it isn’t doing it (yet). Hoping like hell it stays this way.
John
Tried all that.  While the rubber boot was slightly loose, this suggestion did not fix my rattle. Back to the drawing board.
Ugh - that sucks mojohn.
I have to figure out what's going on with my passenger seat.  It will be fine for a few days, then someone will sit in it and then it will rattle like crazy (on bumps) until I start messing with it again.
Still looking to see if anyone with running boards was able to solve the issue by retorquing their bolts.
Fixed mine yesterday by pulling the trim off of my B Pillar and securing the seat-belt pass-through about 1/2 way down the pillar itself. I used sticky felt pads. The loop wiggles side to side on a rivet and contacts the channel on both sides... So far so good.
I hope it works for you, but I've tried that and had no impact.
On 5/16/2019 at 3:11 PM, mojohn said:
Well, she-ott.
Fix didn't take.
Hope springs eternal.
Folded a towel over to @4 layers thickness. Closed the rear passenger door on it,  it's next to the b-pillar, below the rear door hinges. A small amount hangs out from under the door.
Noisy hinges I learned about here, post #84:
 https://www.coloradofans.com/forums/177-2nd-gen-interior/266250-rattle-near-seat-belt-cover-5.html
Been out on several trips, and it's working so far, so good. Wish me luck.
Best,
John
Edited by mojohn
Clarification
I uploaded a video of where I think my noise is coming from.  I was working the back door back and forth and you could hear the metal under the b pillar clicking.  It didn’t totally go away like I thought when I was recording the video, but the pressure helped reduce it.  Sorry about the shaky camera at the end.
    • $3.90 to $4.50 depending on the brand and location of the station. 87 regular.
    • Guys that read Dizzy's thread know that eons ago after multiple manifold pulls to clear the CCV orifice I converted it to a PCV system with an orifice below it via the valve cover. The blow-by (sticky rings) was so bad it was impossible to keep clean and accumulated water in the oil in the winter when the moisture would freeze in the fresh air side. The PCV functioning mainly as a check valve. I carefully sized the orifice to reproduce the factory values for crankcase pressure at idle.    Well...took a slug of oil to get my attention but the ring seal improvement meant the system was over drafting sucking oil up and out the breather. (V8 guys with orifice systems are nodding their heads). So today I choked it down...allot....to replicate the "just enough to hold a piece of paper on the fresh air side at idle". May still be to much but I'm working with shims at the moment. When I get it sorted I'll make a proper plate and plug. Perhaps using carburetor jets to tune it.    So I guess this means it isn't my imagination.    Dizzy is a pig guys so don't go expecting huge moves in equipment (your equipment) that is in much better shape. A needle valve....lord that just came to me....
    • I had a new engine installed with under 5,000 miles. It shut off coming around a residential street corner and wouldn't restart. Dealer indicated it seized. New one has been fine since with 10,000 miles on the replaced engine. Annoying but I was given a loaner for the 5 weeks it was down. I won't go with the 6.2l gasser so it's 3.0l again. I love the economy and it tows my enclosed car trailer just fine.
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
