Bring on the Black Friday deals!!
bndawgs
  • Replies 34
1 hour ago, Waterfowler41 said:
I like the mystery in the Friday sale!
probably only 15%
Looking for a deal on wheels. Hopefully fuel wheels
Look at Methods too...personally I like them better than Fuels
17 hours ago, Eddie 70 said:
I would like a cordless impact wrench so I can remove wheels and tires for rotation. Not sure those 1/4" deals at Lowes and Home Depot can do the job. Anyone try them out?
16 hours ago, cbrsilv15 said:
No. I use a craftsman 1/2”. Works great. My 1/4” doesn’t have enough torque. Works great on all the small stuff, but I only use the 1/2” on lug nuts.
The 24v Brushless Impacts at Lowes have the following specs:
1/4" 1800in/lb (150 ft/lb)
3/8" 150 ft/lb
1/2" 200 ft/lb (650 ft/lb break away)
I have taken lugs torqued to 100 ft/lbs off with the 1/4" impact, it wouldn't be my go to tool the 1/2" removes them with zero effort.
The great thing about these over the others on the market is the power of the 24 volts and that they put the electronics that are normally in the battery in the tool.
This makes the batteries very cheap:
Kobalt 24-Volt Max 1.5-Amp-Hours Lithium Power Tool Battery $10.00
Kobalt 24-Volt Max 2.0-Amp-Hours Lithium Power Tool Battery $20.00
Kobalt 24-Volt Max 4.0-Amp-Hours Lithium Power Tool Battery $50.00
Kobalt 24-Volt Max 5.0-Amp-Hours Lithium Power Tool Battery $89.00
I have 5ea of the 1.5-Amp-Hour batteries that I rotate on the charger, it lets me keep a battery in each tool I have and gives a total run time equal to a 7.5 amps for $50.00.
The 1.5 has enough power to run the Lowes flashlight at full power for over 7 hours continuous. The battery is a loss leader for Lowes it has 6ea Samsung 18650 2500mAh batteries that sell for over $5.00 ea. I bought one just to take apart and harvest the batteries for my tactical flashlight.
Just got the 20% off MSRP email from Chevy for accessories as well.  Same code BF20CM
Chemical Guys is have 30% off entire store.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Any code? Or just 30% off everything already?
I believe it's 30% off already. Didn't see any code to enter. It's good until November 28th.
