9 hours ago, pgamboa said:
Yes PM. For some reason replies to my thread are not notifying me. Using the @forumname does send me a notification so thanks to @2017_whiteZ71 for that!
Phil...PM"d you 6 days ago, did you receive? Thanks, Rick
I'm assuming this was my truck [emoji4]
Could very well be... we’ll need to explore this if this is the case :). Text me for more troubleshooting.
Can you send me another PM to bring it to the top? I get 20-25 PMs daily, so it could have drowned.
My apologies. I usually respond within a day or two.
Has anyone purchased a 2014 full center console, black, white stiches, silver trim?  If so, do you have the part number listing and a source?  I want to upgrade my 2014 but I do not want the wireless charger version.
Thanks,
Rick
So... been reading all the posts and I think your harness can help me if I buy a 2018 Module. I have a 2017 sierra and previously tried to remove the little sticky piece from the original module. It would charge my Iphone 8 but it was sporadic so I gave up. Now I hear if you remove the little magnet as well it will work. Any insight into this? I guess my other option is to buy a new module and the wiring harness you created. If so, it is still available?
Hey Phil,
I rec’d the center console harness today. Got it all hooked up and was going thru and checking things to make sure it all worked.
I did a 2018 console, blk to brn cable and the blk to grey cable, grn to blk stayed in the glove box.
I did notice that the usb inside the console does not allow for car-play, but the front usb hub does, as well as the glove box usb.
Is there anything that can be done to fix the usb hub inside the console to have car-play? I have owned a 2016 1500 LT and a 2016 2500 LTZ (both with center consoles) and on both the usb inside the console allowed for car-play.
Thanks again for all you do here on the site! Much appreciated.
Big Rog
I'm wanting to swap full console for jump seat. Is there a harness for that?
Johnny01: Would you be interested in trading. I have a black with white stitching leather jump seat in my 2016 chevy Silverado. The truck only has 6000 miles on it. If they will interchangeable and yours is the right color. You can email me at [email protected]
Sent from my SM-G935V using Tapatalk
20 hours ago, b-garage said:
Hey Phil,
Big Rog
Phil messaged me back and said that some have reported this while others have not.
So, this is what I did:
I ran the blk/brown cable from blk HMI to brown usb inside the console. This feeds the usb hub inside the arm rest area. Checked and car play now works at the usb connection inside the arm rest area.
My next thought was to run the  green HMI to the input on the double usb connector of the front upper console part, and run the output to the usb in the glove box.  This meant I would need the grn/gray cable, but I had purchased the blk/gray cable. And also would need a black to regular USB connector. Not sure if they even make this or not.
But I had some wire cutters!
i cut he blk/gray cable in half, and did the same to the grn to USB from the glove box. Swapped ends so that I ended up with the glove box USB with a black connector on the other end instead of a green. I then plugged the blk end into the output of the double USB hub in the front upper console and the other end into the glove box. I went ahead and ordered a new grn/gray cable, but just to test things out I spliced the left over ends to make a grn/gray cable. Plugged it in from the grn HMI to the input of the double USB hub in the upper front console  and now have car play at all three USB locations!
Go figure.
On 2/15/2018 at 4:57 PM, DSlade said:
pgamboa
i have a 2015 Silverado. how can i purchase your harness?
Hey Phil,
i have my 2017 Silverado and I have an OEM console on order now. I have the bracket and side trim on order as well. The only thing I need is this harness correct? Please let me know what else I need fin anythjng and I would like to order the harness throug you.
Go figure.
Thanks for providing this detail.  It difficult to fully understand the signaling flow and can only take things based on my personal tests :).  There are many that were successful in using the cables that I suggest while others are not.  Makes me think the output of the double USB is bad?  Anyhow, thanks for sharing this!
Check out my thread here so you have an understanding of all the requirements for this upgrade.  Then PM to order.  Thanks!
http://www.gm-trucks.com/forums/topic/207916-2014-k2xx-center-console-retrofit-plug-and-play-harness/
27 minutes ago, Matt McQuown said:
Hey Phil,
Harness and 2 USB cables based on your center console configuration.  Please see thread here.
Interested in a plug and play harness for my 2017 silverado. I have the center console, side trim, and front bracket on order. Please let me know what I need to do to order the harness from you.
Thanks.
OMG!  I'm going to get my console Thursday!!!!  I'm so excited.  lol   Taking out the jump seat to get with Phil.
Damn!  I don't have the size of bit to unscrew the seat!  To the hardware store!!!
