Are these available for the 2018’s also do you have the harnesses without the 110v?
Edited by Chard220
Yes - available for 2018. 2018s weren’t out yet when I made the video.
Harnesses are built the same with/without 110v. You’ll have a dead 110V if your truck didn’t come with it. You can also add the inverter and wiring to Gain it.
Is there anyone that has removed their jump seat and ashtray that would be willing to sell them?  I am looking for black leather for a 2015 LTZ.  I am located near Lexington, KY and would prefer something within driving distance if possible.
Do you offer the inverter and such with the harness?
When I get a dash take off, I usually pull the inverter and wiring and sell them for $150. If you PM me, I can add you to a wait list for one.
I’ve got an ashtray trim I could sell ya. $60 shipped anywhere in the US. Comes with the 12V outlet and 110V outlet.
I got one off of a 15 Silverado lt I'm willing to sell but I'm in canton Ohio might be to far sell them both for $100 it's not leather but it is blackSent from my SM-N960U using Tapatalk
A guy in Tennessee was looking to sell a leather jump seat..  Not sure if he got it sold or not...
I guess he already sold his...  Good luck...
I have a black leather jump seat took out of my 18 had 100 miles on it also have dash peice. I am in Frankfort my.
Just sent you a PM
Did this swap over the weekend.
Purchased all of the parts including the console from PGamboa. The console arrived very well packaged and was exactly what I asked for. The wiring harness followed quickly behind. Everything fit up and plugged in perfectly and was exactly as advertised. The harness is as good or better than OEM quality. I was legitimately impressed when I pulled it out of the box. The swap took me about 2 hours start to finish, but there were a couple of interruptions and my tools were a little scattered since that wasn't the first thing I tackled that day.
The only "gotcha" moment I had was mentioned earlier in the thread, and that is the trim panel that wraps around the driver's side dash support next to the accelerator pedal needs to be pulled off in order for the console trim panel to fit properly.
I would highly recommend Phil and his products. Everything shipped quickly and was of excellent quality. Now I just need to figure out what to do with the jump seat in my garage.
I’m interested in purchase of your plug and play harness for the center console swap
I have a 2018 Silverado LT and purchased a new 2018 center console.
How do I proceed ?
How do I proceed ?
Send Phil a private message....  Very good to work with and he will get you set up...
If I didn’t have to ship across a border I would have done this long ago. Trying to source the console locally so all I have to get shipped is the harness. Maybe I should order harness now because of high demand? Hmmm....
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
