Does anyone happen to have the PN for this '14 - early '15 jumpseat harness with the 23 pin connector?  Thanks!
I have a 14 console harness with the 23 pin connector I traded trucks and bought a 18 and had to get Phil to build me a harness.
Does anyone know where the best place to get the USBs needed for the HMI for the center console? I’ve ordered the 3 cables needed off of Gmpartscenter.net and the cables have been on backorder for almost a month now. If anyone could give me a better website to order off of that would be awesome! Thanks!
On 3/23/2019 at 12:34 PM, pgamboa said:
Usb cable part # 84022323 is on a National Backorder. There is no ETA in sight and for those online sites that “have it”, most likely, they won’t as they generally all order from the same GM.
An alternative to this Cable and the other usb cables needed for this upgrade, is to get Generic ones from amazon. Trim the ends off until they fit.
Like this.
3ft CablesOnline USB 2.0 Mini-B... https://www.amazon.com/dp/B00T28JQUG?ref=ppx_pop_mob_ap_share
Hey you all, need some help. I have everything I need to complete the center console swop from jumpseat except I am having trouble getting the black to brown usb cable. I know it changed to part number 84022323 but every where I try to get it will let me purchase it but I get an email a day or two later stating it’s a discontinued part or it’s backordered from GM. Does anyone know where I can find one or a way to work around it to power everything inside the console? Appreciate any help!
Big thanks to PGamboa for getting my console and everything needed to make it all work.  Couldn’t be more pleased with how it turned out and dealing with Phil.  Top Class fella.  One stop shopping for complete console set-up.  The easiest way to go.
Does anyone know if the wiring is the same between the variants of center console layouts?
I have a 18 Silverado LT that came with a center console but with only 3 outputs: 2 separate 12v plugs and a dual USB.
I noticed the Denali and LTZ have an additional 120v outlet.
I would like to add the 120v. Is the wiring for the outlet present just left unused thus making things a simple plug and play?
The wiring for the 110v outlet is part of the dash harness.  You will also need the inverter that is in the dash to get it operational.  The portion of the inverter wiring is wrapped in orange tape and the inverter is located down and to the right of the IC and above the accelerator pedal.  The module can be seen in the pic nearly directly in the middle partially hidden behind the cross bar support.  I believe I saw @pgamboa answer another member regarding this but I don't remember in what thread.
Edited by BlkSS
The 110V outlet can be added like@BlkSS said. You’ll need the inverter and wiring. The wiring consists of about 3-4 wires that need to land in various connectors.
I’ll have a kit for this soon... working on sourcing all the needs.
The 110V outlet can be added like[mention=166585]BlkSS[/mention] said. You’ll need the inverter and wiring. The wiring consists of about 3-4 wires that need to land in various connectors.
Thanks guys. I’ll be waiting for that kit!
Hey guys - just wanted to provide a quick update and lead time for new orders.
Currently working on 3/26-3/27 orders today.
Thanks for your patience!
hey guys ,
just bought a used Center console  and its missing one of the brackets (circled in red)
does anyone buy by any chance have any information  about it , I could not find it online , also did not find a part number for it
Thanks
5cb76d0773b17_ScreenShot2019-04-17at5_40_48PM.thumb.jpg.bffc9988ac956600d4a25c0e317a508b.jpg
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
