Nice truck, still can’t stand the chrome window trim or door handles [emoji22]
Ryan B.
21 hours ago, eppieguy said:
Shipped to dealer and installed at dealer.
Did they give you the steel wheels? They would be good for dedicated snow tires.
They won't, supposedly $1,500.00 core charge, they are supposed to be returned to GM, You can buy them on eBay though.
That’s part of the gimmicks dealerships do, sell you custom wheels charging premium price for them trying to keep your original wheels that you’ve already paid for through your window sticker package that came on your truck. I bought my wife a beautiful Volvo XC70 AWD T6 Turbo as a city car for the kids, (that thing was fast) installed video screen headrests replacing factory, asked them to make sure to leave the original headrests in the back seat. They first said no they keep them so I asked parts how much for replacement of the headrests, $600 so I told the dealership give me $600 or I’ll bring charges up as theft and if you still decline, I’ll put you on the evening news. Lol, Volvo has been gone years and I’ve still got those headrests in the garage.
Sent from above
Sent from above
Huh? The dealership put on the wheels that are on your window sticker and they take off the black steel shipping wheels and return them to the factory, not sure what you're taking about with taking something off that you're paying for when you are not paying for the shipping / in transit black wheels.
GM actually notates on them to not be used for regular driving lol
16 hours ago, KozzyJr said:
Looks good. What’s the tire specs?
275/65/20
They are still DOT approved.  They are as roadworthy as just about any aftermarket wheel you could put on there.  That GM sticker is pretty meaningless.  It does prove the point that GM isn't selling you two sets of wheels and then stealing one though.
In any case I eventually gave up on them.. to put them on the '19 I'd want to spend a bunch refinishing them to look good, and that retro look is going to look way better on my rounder/smaller GMT800 Denali than it ever would on the T1.
Went with 20" CK805 Denali wheels instead.  Smaller wheels give more sidewall so they're better for winter and offroad use while still leaving room for a BBK.  Similar but slightly different look from the polished aluminum HC Deluxe 22s.
I’m sure they’re just fine and I’ve seen several trucks with modified sets, I’m just pointing out the goofy shit GM says
On 1/16/2019 at 9:29 PM, RyanbabZ71 said:
Nice truck, still can’t stand the chrome window trim or door handles emoji22.png
Ryan B.
I agree Ryan, color matched all the way imo.
Blizzard coming this afternoon, probably the last time the truck will be this clean until spring...
 9F610647-FE90-4A1E-8426-E7546BDFA28F_zps
22F3FD58-7794-4837-8F9A-EB7C0564CC3B_zps
1DB9A9D2-EEAA-42D4-ABDD-03B1A87A9C74_zps
  • Like 9
On 12/29/2018 at 11:28 AM, block8head said:
Damn bro. That is a sweet looking ride. Love the 157 WB
12 hours ago, FirstAscent said:
Just a quick pic, can't wait to get rid of the chrome!
Some of that is stainless. :seeya:
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
