2016 Chevy Silverado 4.3L V6 3.23
Reading through the manual: Max Trailer Weight 5,600 lbs, any other weights/limitations I should focus on ?
Looking into installing Class 3 Trailer hitch, is a class 3 pretty standard, sufficient ?
Im interested in 17-21' fiberglass center console in the future, any issues towing this type of boat (not knowing weight of boat / trailer etc )
You’ll need to find out the weight and trailer weight combined as well as your gear and occupants. A weight distribution hitch may be required if it’s a pretty long length of a trailer, I’d get one anyway. Make sure you’ve got a trailer brake and trailer brakes too [emoji6]
Sent from above
Load trailer evenly. And always have a trailer braking system factory or otherwise. If express way driving is in your future there are trailer sway bars. I watched my uncle tear up his thoe. 5 people in it with packet full no braking system and he reversed camper in with sway and almost flipped it then two days later flooded the camper the under side held the water all in hundreds of gallons. It was all totaled out. Over a idiot and no $50 part.
You need to figure out what boat you're getting before you do anything to the truck
Is this English lol!
  • Like 5
1 hour ago, TXGREEK said:
You’ll need to find out the weight and trailer weight combined as well as your gear and occupants. A weight distribution hitch may be required if it’s a pretty long length of a trailer, I’d get one anyway. Make sure you’ve got a trailer brake and trailer brakes too emoji6.png
Who the hell is using a WD hitch with a boat trailer?  Especially something that his truck could tow?
Nearly all boat trailers use surge brakes, so WD hitches won't work.
Why not just put a Class III on his truck?  They are rated @ 6000lbs, more than his truck is rated for, so that's not really a factor.
I’ve seen it on some legally maxed out, depending on his setup. Personally, I used my DMax setup in bed for mine.
Sent from above
Just trying to see if what I currently have, basic stock Silverado 1500 V6 can handle handle like a 19’ CC keywest. Seems like these boats weigh about 15-1700 lbs plus motor and trailer. From the manual, I believe class 3 hitch setup should be ok.
Not it sure about WD hitches, that seems  unnecessary for what I need.
Weights you need to pay attention to are tongue weight which goes towards your trucks gross weight, trailer/boat combination total weight, and truck trailer combined gross.  If you go over any of those you're over.  With half tons you usually hit truck gross first.  Your manual will tell you the different weight limits and the door jamb sticker will have a couple as well.
Sent from above
Some trailer makers specifically state not to use WD setups.  Mine says not to even though someone in the last 30 years welded part of a system onto the trailer.
There are WD/sway controls that are made to work with surge brakes.  Boats seem to be a catch 22 when it comes to towing.  Used to be in order to hit the max numbers for your truck you had to have a WD setup. That's why there are 2 numbers when towing with and without WD.  The catch comes in when the boat trailers state not to use WD setup.
Similar the the OP, I need some help with towing.  Is there anywhere that will explain the controls I have in my truck?  I have a trailer symbol on the right control knob ( the shifter).  And I have a slider switch up on the dash over the light control knob.  What are these things?  I have verified the my truck has a towing package.  Any direction would be appreciated.
Did you get an owner's manual with your truck?  These features along with useful tips are explained in the book.  This may also be online.
  • Thanks 1
Head over to keywestboatsforum.com.  Lots of good info in the Trailers and Tow Vehicles section about what all of us are towing our Key West boats with.
I'm pulling my 176 CC (17'7") Key West with my 2018 5.3L, 6 speed, 3.42 geared Silverado LT with factory towing package and no trailer brakes. No issues with starting or stopping.
  • Sad 1
Yes, but when I had a 4x4 question, someone was able to direct me to a YouTube video that explained everything in a way that really helped me understand. I was hoping someone might have a link like that on the towing controls.  It’s one thing to know what they are, I don’t, and another to see someone use them. Thought the point is taken.  I’ll see if I can find some search terms in the manual.
You’ll likely be fine with a boat in that weight range. A dual axle trailer would be best with a boat of that length. Find a boat you want and run the numbers to be sure. Boats can vary a lot in weight even if they’re the same length. Also, 4WD can be very useful on a slick, steep boat ramp... not necessarily a requirement though.
Thanks for the info!
Thanks, I’ll check it out
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
    • Forgot to mention that this started after changing the oil I use mobile 1 full syn with mobile one filter but I did add pro lube additive and was the first time doing so and is making me wonder just can't see why that would matter
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
