I picked up my new 2500 crew cab diesel on Saturday, traded in my 2016 silverado 1500 crew cab.  This is the first diesel I've personally owned, but I have years of positive experiences with other duramax equipped 2500s, a 2013, a 2017, and another 2020.  I'm looking forward to having my own.
Pic of my new one.  And pic of the new and old.   New is 3500HD Denali and old is 2007.5 Silverado 2500 LTZ shortbed
these things drive so well with weight.....not even close to 1500 for hauling..... havent had to haul much since ive had mine but today i had 2500 lbs or so in back and was a dream
Pic of the new rig...3500 Denali HD Duramax. I absolutely love this thing and has been my preferred driver since the day I got it. Can’t wait to start doing the mods on it. I already put a McGaughy’s Leveling Kit and new control arms on it...now looking for new wheels and shocks!
looks great. what size is their kit?
Kylant- Thanks! That’s the pic before the kit and here is one after. The kit is advertised as 2”, but the shop who did mine, dialed it in to make sure the front wasn’t higher than the back. I also replaced my control arms with McGaughy’s. Believe it or not, it drives much better now.
I traded my white 2020 HC 2500 Duramax for a 2020 Silver HC 3500 Duramax.  I had just over 40,000 miles on the 2500.  I went up one size on my tires from 285/65/20 to 295/65/20 Nitto Terra Grappler G2's.  Rims are 20x9 +18.  Kept the bars stock on the 3500, just pinned back the front of the liners a bit with zip ties.  No rubbing at all.IMG_6672.thumb.jpeg.272517fb139e28626196f529a84d8af9.jpegIMG_6673.thumb.jpeg.3d60a9a0e66707ece630c51bbbabeb5b.jpeg
On 10/1/2020 at 6:38 PM, Stand By said:
Thread needs a bump.
Everybody got wet and dirty yesterday. Gibby's first kill is also her first double.
Edited by Stand By
My new 2500HD Custom.  Leveled with 20X10 Wicked Off road wheels -24 offset. 12.5X35X20 Toyo AT3's. Fab Fours Matrix front bumper. Love it so far!
Ol'Rob
  • Like 4
Ol'Rob
Any side pics of those tires? Not many out there yet
Just picked up my new 2020 3500 LT crew cab gasser in Northsky Blue yesterday.  There aren't a lot of blue ones on this thread and there needs to be more.
I traded in a 2015 1500 in Rainforest Green with 121k on it.  The upgrade is for pulling a travel trailer that beat up my trans and suspension pretty bad.
Just recently bought this after getting into an accident and totaling my 2020 Silverado 1500 Trail Boss.  This one is a 2020 GMC Sierra 2500 SLT with the 6.6 gas.  Im really enjoying it so far.  Getting the spray-in bed liner and tonneau cover installed this weekend.  I really am not liking the rims and tires at all.  I want to keep the suspension completely stock but would like some new rims and tires that offer a more aggressive look and are good for snow and ice (I live in Alaska).  Ill also be replacing the factory side steps with all black tubular steps.
Im considering Fuel Blitz or Warlord rims in 20x9 and Ridge Grappler, KO2's or Duratracs for tires.
    • 3.41 Kroger’s in Montgomery TX
    • I really wanted to go to the Fox 2.5's But they were like ~$1,500 vs ~$425 for the Bilsteins. And my research on FOX shocks was that they do not have a great reputation for longevity. I am sure they the FOX's are fantastic, but I know from experience the Bilsteins are rock solid for at least 150k miles.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
