Live Post: May 8th/9th - 2014 Silverado First Drive
Zane
That sketch of the interior I did kinda like that better, especially where the window buttons were located.
Was there any Sierra's there?
  • Replies 100
nice stuff so far thanks for the pics. I too really like the sketched interior. Any word on plans for colormatching options on the trucks? Is there anymore ground clearance stock from the current 900's?
There were no GMC's this trip, Chevrolet only program.
Colormatching?
Ground clearance.. no big change...just the air dam will make a difference.
Yes, I'm sure as easy as the 900s. With the new design, you may not want/have to.
colormatching - like the current Z71 appearance pkg, grille is painted body colored not chrome.
Thanks for the reporting and pictures. I am starting to like the new Chevy more and more! Cant wait to see one live and in person. At some point this old F150 will need replacing and can't wait to get back to a GM product!
Sent from my Galaxy Nexus using Tapatalk 2
Not weak..just harder to keep in V4. I liked the cooled seats but they are noisy and yes, have exhuast to the rear seat. Not sure it's hot air though.
The fabric lined wheel wells are to quiet things down when it is raining.
Again, you're the first to say that they are harder to keep in V4 mode. I have a close coworker that spent 5 days in both trucks and that's where my information is coming from.
Yes there are issues being reported from ctf evaluations.
Well aware of what they are there for. Buick and Caddy have had them for a while. Just not a fan of what they are going to look like and how well yet are going to hold up on say a farm truck. It's going too far on a pickup, IMO.
My experience is limited compared to your sources, I'm sure ChevyTech77. I only drove the Crew Cab 4x4, with the 4.3L. Obviously, the heaviest package.
I know you know this stuff, I'm just trying to explain for those who do not. It may not be obvious why there is fabric in the wheel wells. I also agree, mud and fabric don't mix, so it will be interesting to see how they hold up.
It was clear to me, after driving the 2014, that the goal was to make a truck that's more "car like". That said, the capability has not been diminished at all in the process.
What gears did these trucks have? I'm sure GM is out to impress with fuel economy but I couldn't care less about that so if these were neutered with 3.08 gears I'd be curious to see if the 3.42s make much difference. Like you said these are as heavy as heavy gets so its not a great judge of performance.
yeah that's what I was thinking, but more so the mirror caps and door handles as it seems the only options right now are chrome or the black plastic on those two areas.
Im curious of the mileage numbers and towing power of a Max trailering pkg crew cab 4X4 with the 5.3 and 3.73 gears VS. the 6.2 with regular 3.42 gears. Also, are the max trailering pkg's on this bodystyle required to have those small base pkg wheels like on the 900's. Hopefully not.
I hate that chrome trim on the doors, it is cheap looking.
Does the tapshift system work the same as before (ie, limits the gear range) or does it physically force a gear shift this time around (ie, a true manual mode like in the F150's).
Sorry to dig this up again, but any word on how the manual option works? I really like to be able to force the transmission to change gears when needed (Force an upshift or prevent a downshift).
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
