My first truck was that bad... After they replaced pretty much everything rear or the tranny, including the rear end, it never got any better... Good luck
Did you get a new truck?
GM and my dealer ended up buying it back and now I have an LTZ Z71. My first was an LT 4x4. That truck had literally everything replaced and no fix. GM gave me "Trade in assistance" along with the 35 K the dealer gave me. I put a new set of tires on and its as smooth as glass now. I ended up paying like $1200 difference for the LTZ otd.
I have an idea... Someone put their truck in M5 and go cruising down the highway at 75 and see if it goes away. This would eliminate the 6th gear which is where most of us are feeling it on the highway, and see if its a tranny problem.
I'll try that next time I hit the highway. In the meantime I will just try to not think about it . Kinda ruins the entire weekend after u pick up your new truck on Friday after it was in the shop for the third time in the past month and it's not any better.
Although I have not experienced the problem with my truck I did with another motor that wasn't running on all cylinders. Could it be the AFM that's not letting the motor run on all 8 cylinders?
Sent from my Nexus 7 using Tapatalk
Or timing off via screwed up software?
Mine isn't that bad...but bad enought to be annoying. I've tried stepping on it a bit and it does it in V8 mode too....even after it's downshifted to another gear. I think I even tried shifting into Neutral and coasting over 70 and it did it. It seems not to be AFM related, or transmission related, at least with my truck. Completly dependent on rolling speed...over 70 and for a few miles before it starts happening. The warmer out, the worse it is...the higher the tire presure, the worse it is. Yesterday we took a family day and drove backroads up to 5o-55 to the beach, shopping, and out to eat. It was a nice day and the truck drove beautifully. We drove something like 92 miles, and averaged 21.4 MPG! If this truck wasn't so damn nice looking, and got such great fuel economy it'd be in big trouble LOL! I was set to buy tires and an alignment...but now I'm taking it in Tuesday and letting them keep it a while and see what they find. You have to try that first and who knows...they may fix it. This CANT be a mystery forever. I dont think there's ever been a vehicle made that an issue with it remains a mystery to this day. They'll figure it out. The service manager I spoke with did say they've seen alot of them coming in for vibration, and it seems like both GY and Michelin tires are on trucks that vibrate. He did say recently, they had to shim a rear end on one truck, and an engine mount in another to fix high speed vibration. He seems like a real nice guy, who wants to get to the bottom of your problem so that's promising. We'll see what they discover this week.
Edited by MJFlores
Let me just say this, there is enough people out there with this issue that GM must have an idea of what is going on!
Are they not doing anything about this? Or is it because it will be too costly to fix all these trucks now, and it is only a vibration right.
Everybody you need to report it to your local government agency like NHTSA with concerns that new vehicle s should not vibrate, and it is not safe!
Also report these tires, they are not right with the sidewalls deforming this soon.
Speak up people, and enough of us they will have to investigate our concerns folks.
Then we may learn the truth about these trucks.
I had enough lies, I have started legal actions to correct my vibration!
I also reported my concerns over safety with this truck too.
Well as I was researching the vibration issue some more I decided to make a quick video of my idle vibration . If someone who has a smooth riding truck could create one to show it is not just engine related that would be cool! So here is my truck idle with some vibration .
Do you think some of your shaking issues could be related to the lift kit on your truck? And do you really think comparing it to an Escape is a fair comparison?
Mike
Glad you got a new truck! And glad your new one is vibration free!
Mike
Well I don't have a spare 60k $ truck to compare it to in my possession so I'm working with what I got :) a 25k$ Ford . That's why I asked if someone like yourself could post one . Did you read that part?
And also I had a 2011 with the same lift and tires/ rim size and it did not have any issues with this much vibration. but to answer your question I have considered the lift to be part of the problem but the dealer has not found anything wrong with the lift . Had a new drive shaft installed that helped a little and the tires force balanced twice . My salesman said the others he has sold with exact same lift and wheel combo are not having the problems I am ...
    • It definitely seems quite evident that emissions and fuel economy targets rule above the best case scenario of what the engines best health and life could be otherwise. Items like DI and turbo DI engines with their LSPI issues as well as cats being reduced in life if the proper levels of certain additives were allowed to be utilized and so something has to be compromised and as you point out that is the engine protection from sludge, acid and wear which isn't in the manufactures best interest regardless to worry about in this race to profits from higher sales and so if the engines wear out sooner the next sale is closer at hand.    I am hearing that its likely the two new 2027 GM half ton truck engines will call for a 0W-30 oil, now if that is an existing oil I would have to think so but we will see in the coming months. Sadly as you've pointed out to me, over the last number of years the push has been on to reduce the actual operating temperature viscosity within each designated viscosity grade so that 11.5 to 12 range for a 30 weight for example is more in that just above 10 range at 100c along with that temporary viscosity sheer dropping it even further down as per that "energy conserving" designation, not to mention how some oils are not as sheer stable as would be ideal and that mixed with a long OCI paints a picture with a little too much glitter shall we say !.    All that and the warranty gods scaring the vehicle owner into sticking with that watery wine or risk loosing their warranty coverage if they go and use an oil that is of a higher viscosity even if it meets the emissions and LSPI requirements and would never damage the engine but may very well allow for an engines longer life depending on engine use scenarios ... high ambient temps, towing etc that push oils to their limits.
    • Very true.   However.  GM did give those trucks with the single speed case Terrain Mode.  Terrain Mode mimics 4LO minus the gear reduction and torque capability.  It uses the ABS/braking system to perform the operation.  It also gives these one pedal driving (sort of) when in Terrain Mode via the active brake during throttle lift.     Does it have its limitations over a true 2 speed case?  Sure.  But it works.
    • Of course actually engaging four wheel drive is step one or even daring to use a ramp like that with a two wheel drive and getting into a mess because of it. As to 4 low, these last few years if its a GM half ton it may not even have low range. A lot of the newer pickups have a lot lower first gear in an automatic transmission then they once did as it was common at one time for a gas engine truck or even the older diesels to just sit there and bog the engine due to the torque converter stall point and not enough torque was generated on reasonable traction to even spin a tire or get out of its own way up a steep grade and 4 low HAD to be used to get enough power to four tires to get them turning. These days traction control systems may hinder a vehicle in a situation like that although that means a tire or tires are spinning so in some ways the traction control can reduce wild spinning and anyone can correct me on that but I think some vehicles cut traction control off in low range ?.    By the sounds of it and you may have the proper equipment but if your responsible for helping vehicles out if they are not able to get out under their own power, I would say to be using a nylon tow rope or have one available so that one is able to give a bit of a run to help sling shot them some initial momentum as most tow straps are made out of polypropylene and impart way too much shock load if used to jerk a stuck vehicle into motion but are totally fine to use if going more from almost a dead pull with the tow vehicle and they are a lot less expensive to replace if damaged. That and some soft shackles to hook onto closed loop tow hooks on the truck your pulling as well as you having the proper shackle insert in your truck so there are no bad accidents with metal clevises joining things together or chain on the end of a tow rope or tow balls being hooked onto etc flying and causing damage or worse if it lets go. Its always a challenge pulling people because some are clueless and will over run the tow rope or strap and drive over it or that risk of ramming into the back of the tow vehicle so usually a few instructions are needed to clue in the driver of the stuck truck. Yeah ... have fun out there 😉
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
